Just was looking at the Garrett website and noticed they have put up some new part numbers!
Wonder what pricing will be?!?
Those compressor maps look impressive for big boost and power (should go great with E85!)
Edited by SimonR32
https://www.sau.com.au/forums/topic/344089-garrett-medium-frame-gtx-turbos/
Oooo the 3071 looks brilliant in terms of a good RB25 upgrade/stock motor
GT3076 is very interesting too.
GT35 just gets fatter, almost 10lb/min :dry:
That would be a very good upgrade.
But indeed... all comes down to the price lol.
Interesting if they get some 2860 graphs up.
Found this interesting bit of text on a website selling these turbos.
"This is the new Billet version of the previous Garrett GT3076R model.This Dual Ball Bearing turbo has an Oil & Water Cooled center cartridge. This turbocharger is on track to replaced the older GT3582R model as the most popular mid sized turbo on the market. The original GT3076R paved the way for many performance enthusiasts earning its place as the best all around turbo out there for most peoples needs. The new GTX3076R makes more power, spools faster, and is all around better than the GT3076R."
http://realstreetperformance.com/store/57m...turbo-2009.html
So does this mean that your basically in a gtx3071r youll be getting more power than a 3076 and less lag and with the gtx 3076r youll be getting power like a 3582 with the response of a 3076?
as far as the comp maps show there it will be very close, the gtx3071 map is almost spot on the normal 3076 so they will make similar power but the normal 3582 map still flows a few more pounds/Min more than the GTX3076
Well aslong as gtx3076 makes more power than before without added lag then I think I found my next turbo.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
