Value for money get the turbo with an internal gate .82 turbine housing, get an exhaust cam gear and get it retuned. You will need a line kit, intake and cooler pipping modded and a completely new dump pipe.
GCG have given me a rough price of $2200 for the GTX with rear housing. You can then get your mechanic to make you the dump/cooler/intake pipes and buy a RB/Garrett BB line kit from Kinugawa on ebay. The line kit is about $100 and I anticipate you will need to spend roughly 800 making the dump and other associated pipes. GCG also sell gates cam gears for something like $100 each and tuning will be up to your tuner.
GCG Also sell a complete kit with the lines, dump pipe etc. I believe the price was around $3k for the GT3071/76 so I wonder if its gone up for the GTX series?
6boost mani for $2500??? Last i seen they only 1200bux custom.....
When you go high mount you tend to need more than just a manifold to make it work... also having external wastegate would be a good start ;)
This.
I'll be getting a GTX3582R soon. .82 internally gated. Best I found so far was $2200. Don't need a kit cuz it will all bolt up with my current gt3076r kit. Can't wait :)
Wow thats big news, I cant wait for the results either! So a GT35 will fit onto the standard exhaust manifold? I thought the standard exhaust manifold started to become a reasonable restriction over 300rwkw?
Just checking, i'm sure you can't but thought it would be worth asking as i'm not that knowledgeable.
Could I get a GTX3071 and use the exhaust housing from my current KKR560. I would love that because then i don't need to buy an exhaust housing, dump pipe or any of that, so i'd save money. My current exhaust housing has already been chopped up my mr turbo to remove the "twin scroll" partition, and make the wastegate hole heaps bigger.
Random copy and paste in case it's helpful:
KKR560 One of the largest internal-gate turbos on the market Oil-cooled, 0.84 turbine housing suits T3 size flange Internal wastegate with 8psi actuator Suitable for single-turbo applications on 3.0-4.5 litre engines, or in twin turbo kits on 6.0 to 7.0 litre engines Comes with 71mm V-band section and V-band for dump pipe, T3 exhaust gasket, oil inlet banjo bolt and oil return gasket. RRP $999 Specifications for KKR560core: Compressor inlet pipe 76mm, compressor outlet pipe 50mm 55 trim compressor; inducer 61mm, exducer 82mm Turbine wheel outlet 56mm, outer diameter 73mm
As I said, i'm sure this is a ridiculous question, but thought i might as well ask :)
No you need to change to the garett housing since you will get poor results with the kkr housing.
My vote is for keeping the 3076, go E85 and run 23-25psi. Should make 340-350rwkw, improve your current awesome reponse (E85) and have a spastic mid range and top end!
RB25DETS2 runs a HKS 3037 Pro S on 23psi on E85 on a stock RB25 making 348-356rwkw depending on dyno. As we know the 3037 is a 3076 with a few tricks so is directly applicable.
NYTSKY has also had the 3076 up to 350rwkw maybe even more I cant remember.
I think a GTX35R really demands an aftermarket manifold etc.
Heres to hoping that updates will be posted in this thread as australian outlets get stock of GTX3071.
Just checking... I used to run no cat or mufflers on my car, but i've cleaned up my act now so that i don't upset the neighbors.
There's no problem running a screamer pipe on a GTX3071 right? Like it will only get loud once i'm making some kind of boost, right?
Isaac
I've contacted ATP and RSP to get quotes for GTX3071's internally gated T3 0.82 housing and flange shipped to Gold Coast, Australia.
They replied back to confirm address, so I guess i'll hear back with a price this afternoon. If it's acceptable, looks like i might get the world's best xmas present :cheers:
I'm happy to post up the prices here, for anybody else looking, or is that inappropriate?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
