I have seen the graphs, hopefully he will post them up soon. Split .82 rear with twin 40mm gates. Full boost by 3.5k sounds like a win for a 300kw turbo. :)
Wow, even with a free flowing exhaust mine would have been at best 3.7-3.8, TS makes a big difference :D
Yeh, I thought it'd be nice! Even if you lost 10-15kw worth of flow potential because of the twin scroll it'd still be worth it I think.
Awaits graphs...
Edit: is this the setup status was referring to in the 300kw unopened thread?
Edited by Mitcho_7
EPA test is tomorrow morning.. hope it passes....
im going to take the car there nice and warm so the exhaust cat's are heated up and expanded to capture all the crap..
anyone else know of any tricks? :P
I personally know of 4 RBs making over 400rwkw with stock bottom ends on E85, all driven very hard.
A nice safe tune on E85 and you shouldnt have a drama. Kinda makes built engines under this power a waste of money lol
Think i seen you last night going past caltex on canterbury rd around 930pm i was in the white r33.. you almost brought her on boost LOL
Didn't you just build your motor? haha
I'm with you though, if and when mine goes pop another stocker is going to be dropped into the whole and probably given more hurt than this one is copping :)
Ive had 3 built motors lol
At current Im not sure a stock bottom end would cope with 800hp to long.
Looks like its all going to plan Owen, cant wait for Ethanol results! It comes on a LOT harder/sooner than mine so the setup certainly works ;)
yeah, i absolutely love it! its actually a lot smoother to drive than i was expecting.
Big thanks to trent for the tuning!
e85 gear should arrive next week, then ill book it in for another tune! OH YEAH!
Ha! i was the same with mine, was amazed how smooth it is and its better as a daily than it was before...... E85 will be a serious kick in the pants though if your already getting those results :D Keep us updated as itll be awesome to see another one up and going!
thats a nice looking power curve, how come the torque curve doesnt hold a straight line? is it just different dyno's people are using or is the torque really dropping off
It's always going to drop off...
It's not a 800hp setup that makes all its power above 5000rpm
Not always, for instance these 2 cars almost don't drop any torque between 4000-7000rpm
Edited by SimonR32
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
