wow, who would have thought this piece of shit track would bring back boring racing
How in the fcuk are places like this and hungary allowed to be apart of the calander
Well done to vettel, just counting down the weeks until this championship is done. Kind of a shame that with the points lead he has now, he doesnt even have to win or come second to have this all locked up.
Yep, I dozed in and out of sleep, f**king waste of race weekend innit.
+1 to this.
Oh, and am I the only one getting sick of hearing "I have no KERS, KERS is gone"... then said driver immediately puts in fastest lap of the race on their next lap or two?
Lastly, DRS is as shitful a Ecclestone... if DRS must be used, can we at least have it available on corners?
6L atmo? even that is waaaay too quick.
4 cylinder sounds crap, i'm suer v6 wouldn't be that good either. inline 6 is a possibility but for packaging reasons nobody uses them in production cars any more. v8 sounds crap especially with this blown diffuser nonsense.
I'm a fan of smaller capacity V10 or V12, NA. Keep the cylinder count high, no RPM limit, and reduce capacity as required to keep power within sensible limits. Besides that I say "anything goes" with the engine as long as they still sound meaty and not tinny like a motorbike. Not really a fan of turbo, it kills the exhaust sound. V12s were before my time but the V10s sounded magnificent.
Get rid of this reliability stuff, engines and gearboxes lasting half a season etc. The random blowups used to make things interesting.
Aero needs to be simplified still further, to make it easier for cars to follow closely. That and mechanical grip needs to be improved. I think DRS has too many rules, and is a bit artificial. I have no problem with KERS because drivers are free to use it at any point in the lap.
The main thing for me is the sound. In between F1 practice sessions when the two seater V10 comes out my jaw drops and I go what... is... THAT.... :worship:
When did this happen? Lap times drop with fuel loads but I think it is safe to say that KERS makes cars quicker.
as pointless as not even putting in a time in q3? these tyre regs need the most work
from start to finish, this whole weekend has been a complete let down
Refueling would solve so many problems. Two, three or four stints where cars are driving flat out rather than circulating to manage fuel, tyres, engines and gearboxes.
Button did it last night if I recall correctly.
Also I think Webber did it a couple of times earlier this year
Fuel reduction is the main reason plus the on/off nature of some KERS modules when they get too hot.
I agree, but JB did it the lap he was heard on the team radio last night.
Whether the team radio broadcast was quite delayed I do not know.
I think you will find that those messages are delayed, have heard the commentators say as much a few times, was more than likely coincidence
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
