repairable write-off
Someone correct me here, but I thought a write off was the situation when the repairs are more expensive than the agreed value of the car?!
I can't see how a new roof and shit, even considering it's a brand new, top of the range car, would cost >140k.
Yeah? No?
Yeah? No?
give me a second and I'll log into the shop :D I have current LOCAL and JAP FAST loaded there and I can acess a price database fairly easiily.
ok:
G3112-JF0MA - roof panel $1500
731D0-JF00A - roof reiniforcement $1000
73910-JF21A - Roof lining $1000.
79700-JF30B - rear Glass kit - unable to price.
thats a starting point. I have about half a page pf things that 'could' be damaged on it.
in reality I can see $10k in parts myself. especially if it got into the SRS and electrical system.
given that the car has curtains and seat bags and that the curtains are bolted from the rear of the car I'd suggest that they are also part of the write off quote.
power to someone buying it and fixing it. it certainly will not be a cheap evercise.
Guys, both quarter panels are gone, they are welded to the chassis, boot is gone, spoiler gone, roof gooooone, windscreen, interior is completely ruined including seats, glass has scratched the thing to pieces - at $60 k the repair would have to come under about $55 k to make it worthwhile. The car has had a very big impact so suspect some chassis damage, I wouldnt race it with that sort of damage, and at $60 k, do the math.......
get the angles right on camera and you could look as nuts as the boys off jackass...taking a chainsaw to the roof
when you're done hacking it off, whack an awesome cage in it (easy access), and then do a full carbon fibre roof.
job done.
edit - previous owner says it's bent like a banana....dream over.
Edited by tk80
looking further at that - rear quarters both sides ( I had these pegged for replacing.) and prettly much all the hardware attached to them.
G8100-JF0MA - REAR FENDER RH - $2600.
G8101-JF0MA - REAR FENDER LH - $2600.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
