Hurry up an do it, so I can see your results so I can do it with mine lol
Edit - I should be doing mine next year, but will keep the boost down to save the standard auto.
I'm still thinking the Kando Td06-20g Will suit me better as full boost at 4500 is a little laggy through the auto imo
they also make a TD06H...
these all come with the 10cm rear
KINUGAWA TD06H -20G Turbocharger
Compressor wheel: 52.5 / 68 mm
Turbine Wheel: 58.8 / 67 mm
KINUGAWA T67-25G Turbocharger with T3 Flange
Comp. Whee: 60.2/78mm (25G)
Turbine Wheel: 54 / 61 mm (11 Blades)
KINUGAWA TD06SL2 -20G Turbocharger
Turbine Wheel: 54.1 / 61 mm
how would the td06h compare to the td06l2?
Edited by battery
Interesting thing is a GTX3071R flows 10% more than a GT3076R at most boost levels you'd run on an RB25 - imagine one of those on an ethanol blend on an RB25.... expensive, but I can't think of a combination with a fatter streetable power delivery potential.
Without a doubt! All signs point to it being a awesome turbo... They were released only a few days after I purchased my T67 :(
Still as you said fairly expensive!!!
I thought Nytsky made 427rwkw on E85 from a GT35R
Yeah not sure why some people seem to struggle with the GT3582Rs in Oz, one of my mates did 10.6 and had cracked 130mph in a full weight R33 GTS25t running 20psi on BP98 with a GT35R with less than perfect runs - to avoid dyno comparisons its probably worth observing that it has to surely be making a reasonable amount of power?
Really hoping the same car will be tuned on E85 with a PT6765 soon...
My plan was to buy the TD06-L2 and later use my TD07S comp housing and wheel to make a T67, that plan went to shit when some flamin mongrel stole the TD07 :(
Still might do it (the L2) and later buy the billet 25G comp wheel and a port shrouded comp cover to make the T67-25G
385rwkws on pump with a standard cammed/head Rb25 and GT35R? that would have to be the most insane result Ive ever seen, hub dyno or not
Guilt-toy did 370rwkw or so on 20psi with a GT35
3ltr admittadly but it was a stock 25 head.
Im trying to remember but i think he made very close to his E85 power on PULP, because I remember him saying that the standard cams were holding him back once he switched over.
Either way both his and R33_racers were Rb30s which will help power.
I actually love GT3076R's! The cost put me off because it would have been at least a extra $1200ish cost over the top of this turbo and I'm jewish
So I figured saving a lot of money, loosing a few hundred rpm of response and gaining some top end was worth it :)
Actually as you can see from my graph if we revved the old girl to 8500 it would probably come close to 550hp where the 3076R with cams was already starting to fall over.
yeah they will happily make power to 9000rpm on your setup :)
Remember the dyno dymanics stuff always looks more responsive as the extra weight of the rollers adds extra load, we just spent a fair amount of time liaising with another shop and found the normal baseline run we do of 9sec from say 1500-7000 has less low end load applied. So its more equivalent to 12-13 seconds.
I would like to see someone try the Kando T67 with one of the billet wheels I linked up earlier. should bring boost on earlier and carry on in the top end a little more
we did some comparos (billet vs std)with the T88-gk years ago as they originally came with billet compressor wheels, before tooling was finished for the normal comp wheels. There was minimal difference except for production cost.
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
