Still shows that there arent any restrictions ;)
Realistically I think the 20G would just about suit anyone wanting a balls out responsive 260rwkw, maybe more.
I think it would better HKS GTRS results to be honest, thats $3000 worth of kit to be had for $800 on ebay.
this. i'd definately try it if i didn't already have a 2835!
Yeah the TD06SL2 has the same exhaust wheel and housing as a T67 but with 20g compressor and housing to suit. I would still think a T67 would be better on a RB25 and the SL2 for a RB20
410kw was a little bit of a piss take with correction on... More realistically it makes 390kw on a hub dyno and 360rwkw on a dyno dynamics roller :)
I notice you run a Z32 AFM in the cooler piping, do you run a 4" intake off the T67?
Yes, there should be engine bay shots somewhere in this thread...
Actually I blew a the silicon off the AFM on friday night which was a bitch. The only pipe that can't have welded tabs to hold the hose clamp on (because it's plastic) dammit!
In other news, drags tomorrow night. Won't be a good time I don't think because the standard suspension can't be refitted due to alignment changes but will raise my coilovers and use MT ET street and see what mph I can run at least
Edited by SimonR32
Simon - I'd appreciate your thoughts on this. Remember our $ is weak as anything compared to yours if you freak at the price..
I did some road tuning on an R34 RB25DET powered R32 yesterday which is running some Chinese T3/T4 and found the thing was maxed out at 1.1bar, the owner wants 300wkw on pump gas with streetability but like everyone doesn't want to spend thousands - was thinking of suggesting this turbo as an option with 10cm housing if its anything like yours:
http://www.drivenperformance.co.nz/scripts/prodView.asp?idproduct=1810
I was in Auckland a few weeks ago so I know what your dollar is like (actually I took money from your economy because I won like $350 at the casino during a 15 hour stopover haha)
That turbo has the same badge as mine (Kinugawa) so it would be manufactured in the same place and I imagine would be just as good quality but it's not the same specs. It has a much bigger exhaust wheel and a different trimmed front wheel. Plus the front housing is different as well.
That is not the one to buy... You can buy the same as mine from ebay http://cgi.ebay.com.au/Turbochargeri-Kinugawa-T67-25G-T3-10-cm-V-Band-Housing-/270717916046?pt=AU_Car_Parts_Accessories&hash=item3f080b938e#ht_2530wt_1139 or do what I did and email them direct and ask for the best price [email protected] then pay via paypal!
It only took 3-4 days to get mine delivered so it's nice and quick and I got it for about $100 off the ebay price :)
Exactly, this is my answer to the 2835 which I cannot find/afford. Just reference the two states sources, Simons T67 results (for hot side) and all evo 20g results (for power/response indication).
Power and response can ONLY be better going up to a 2.5L limited by the exhaust side choking, enter Simons results.
We have a winner.
Once Im back from my first overseas trip ever, Ill be buying one. Best thing is that even if Kando fold up, mitsu sell all their tooling from panels to turbos so there are more suppliers of mitsubishi turbo parts than you can poke a stick at.
Hyundai motors are all ex mitsu tooling, which is why a hyundai motor is the cheapest way to do a 4G63 conversion lol.
Dont be too stressed about coilovers. My old drift
S13 ran 11.0 @127mph on full drift setup. And had used mt et streets. 1.65 60ft launch.
How is the T67 the answer to the HKS 2835? I thought they would be in different categories. The dynosheets in post #154 show that it is less responsive than a 3076. The 2835 is more responsive than a 3076 again. In the HKS range I would equate it closer to a 3037.
2835 full boost ~3500rpm
3076 full boost ~3800-4000rpm
T67 full boost 4200-4400rpm
I believe they are talking about the TD06SL2
Its the same thing, TD06SL2 and T67 are refering to the turbine wheel. Its the same wheel. Same size same design etc.
When trust do their thing and rebadge the turbo as their own they call the TD06SL2 wheel a T67. Generally because it was trust who mated it to a 25G compressor and called it a T67, not Mitsubishi.
To he who questioned how it applies to a 2835, I have clearly stated the 20g compressor mated to the SL2 turbine wheel (T67) has been shown to spool incredibly well on a 2L motor when using a 10.5cm housing. The SL2 has also been shown to flow very high numbers, with ease, on simons car.
The 20g compressor is 68mm, it is smaller and in theory will spool faster than the 71mm GT35 used on the 2835 and 3071. It also flows 450hp.
2 and 2 somehow make 4, Im just waiting to secure my own 20g and proove the theory on paper. Hopefully will order one next week.
Be a little carefull comparing Evolution Mitsy turbos to other MHI based things because the Evos 4-10 use twin scroll turbine housings and thats makes a significant difference .
Possibly the people to talk to are GT Pumps because they seem to have a good handle on the various Mitsubishi 6 series turbines and TD05/6/7 compressor wheels .
You will find an interesting mix of TD06 family turbines ie TD06-SL2 TD06 TD06S TD06H TD06SH and TE06 .
They can have from memory 11 or 12 blades and I think Mark has most/all on display at his shop .
Where Mitsy is different from Garretts GT BB wheel rage seems to be with trim sizes . To me it looks like Garrett leaned towards big turbine trim sizes and at times compressors too . HKS seemed to take advantage of optioning Garrett compressors of the same families but in smaller trims at times . Importantly they also - oops the signals have cleared and gotta go
More termorrer cheers A .
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
