Spray the top side of the heat shield, might make it looks a bit better without the rust...
Apart from that looks like a tidy install :)
Agreed, it made mine look a lot better. Just black heat proof paint and i used some stainless allen key bolts because i'm a ricer.
Work in progress shot when i was fitting the 3071
Dori what paint is that man? I want to do my cooler pipes in a similar finish.
If anyone is interested my 10:1cr SR made 200.5kw @ 13.3psi on the mainline today, running a GT2860RS disco and failed VCT. Generally those turbos do 220 if everything is good, considering im using the stock AFM with a 40mm ID and the compression of the motor (dont forget its on a mainline) Im pretty happy with that.
Soon to find out how it drives when I pick it up from Jez.
thanks simon,
yeah im gonna spray it when i get a chance to hit it up with a wire brush and some rust protector first.
What gate, looks stock too meeee :ph34r:
Christ, I was hoping i would be able to squeeze in a std airbox with the high mount. Looking at that pic there is no chance.
Bugger pickling. Isnt even buying it a ball ache these days? Just linish the thing and remove any evidence of the weld. If you do the tig weld neat enough you only really need a bit of scothbrite. This is my gay ass old setup and the TB pipe was pretty quick and easy out of some stainless left over from work, a quick rub with some IPA and green scothbrite and you cant pick the welds
my intakes all aluminium..hence all the lobster, the weight savings are enormous
as for the gate pipe, we didnt have any mandrel 2 inch and didnt care
I dont mind cause when I put it all together you cant see shit anyways..
yeah thats right, I still have my stock snorkel bitches.... :nyaanyaa:
unfortunately though my crossover pipe is like 1mm thick rubbsih aluminium, welds sure to snap oneday..
Just need a cover for the gate and dumps now...prolly give some of that heat shield shit a go too..or maybe just some aluminum plate i dunno..
Hey Roy your gay ass old setup looks alright man Love that TB pipe..whats the dud pipe on the intake with a cap on it??
But wait... No CAI box, Isn't that illegal...You'll be sucking in hot air man, this may cause you to lose power and stuff.
Arent you handicapped enough with an RB20 :whistling: .
Man, your engine bay in MINT! I love it.
The dud pipe/cap is where the Greddy kit returns its BOV too. It has since been cut off and welded up. . The other pipe with hose in it is where my catch can plumbs back to on the street. The car once had a shroud over the filter, but it was pretty shit and when it went missing at the mechanics I never missed it or bothered to replace it. That was 2004 :) There are a two ducts (grey corrugated pipe you can just see in the pic) that duct air to the filter. Its still crap, but meh. When i finally get my radiator setup I will fix all the inlet piping
The crossover pipe is gay because I was a tight ass and used leftover tubing from a pharamceutical project I was working on. It didnt have material certificates so couldn't be used...so i grabbed it for the right price: FREE :) Problem is its 1.6mm thick 316L so far heavier then ideal. But a breeze to weld
we all know you're a ricer Dave.
nice weld job on the cooler piping, who did the fab work for you?
I did that stuff for him from memory. It was ages ago but i think that was mild steel which was then painted black of some variety
:thanks:
Something like this this stuff yeah..cant be too hard to mount it..
http://www.thermalvelocity.com.au/Heat-Shields/Vulcan-Heat-Shield-/p-113-475/
Black Caliper paint comes up real good, needs no base coat..Did mine the other day..
Hope u have a safe drive home in the rain dude.
in gate vs ext gate td06l2
int gate 18psi ext gate 17psi
td06sh-25g on sr22 (nistune) low and high boost (red run is 14 sec pull so its artificially responsive) it was done to make sure det was 3-4degrees off regardless of load.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
