Spray the top side of the heat shield, might make it looks a bit better without the rust...
Apart from that looks like a tidy install :)
Agreed, it made mine look a lot better. Just black heat proof paint and i used some stainless allen key bolts because i'm a ricer.
Work in progress shot when i was fitting the 3071
Dori what paint is that man? I want to do my cooler pipes in a similar finish.
If anyone is interested my 10:1cr SR made 200.5kw @ 13.3psi on the mainline today, running a GT2860RS disco and failed VCT. Generally those turbos do 220 if everything is good, considering im using the stock AFM with a 40mm ID and the compression of the motor (dont forget its on a mainline) Im pretty happy with that.
Soon to find out how it drives when I pick it up from Jez.
thanks simon,
yeah im gonna spray it when i get a chance to hit it up with a wire brush and some rust protector first.
What gate, looks stock too meeee :ph34r:
Christ, I was hoping i would be able to squeeze in a std airbox with the high mount. Looking at that pic there is no chance.
Bugger pickling. Isnt even buying it a ball ache these days? Just linish the thing and remove any evidence of the weld. If you do the tig weld neat enough you only really need a bit of scothbrite. This is my gay ass old setup and the TB pipe was pretty quick and easy out of some stainless left over from work, a quick rub with some IPA and green scothbrite and you cant pick the welds
my intakes all aluminium..hence all the lobster, the weight savings are enormous
as for the gate pipe, we didnt have any mandrel 2 inch and didnt care
I dont mind cause when I put it all together you cant see shit anyways..
yeah thats right, I still have my stock snorkel bitches.... :nyaanyaa:
unfortunately though my crossover pipe is like 1mm thick rubbsih aluminium, welds sure to snap oneday..
Just need a cover for the gate and dumps now...prolly give some of that heat shield shit a go too..or maybe just some aluminum plate i dunno..
Hey Roy your gay ass old setup looks alright man Love that TB pipe..whats the dud pipe on the intake with a cap on it??
But wait... No CAI box, Isn't that illegal...You'll be sucking in hot air man, this may cause you to lose power and stuff.
Arent you handicapped enough with an RB20 :whistling: .
Man, your engine bay in MINT! I love it.
The dud pipe/cap is where the Greddy kit returns its BOV too. It has since been cut off and welded up. . The other pipe with hose in it is where my catch can plumbs back to on the street. The car once had a shroud over the filter, but it was pretty shit and when it went missing at the mechanics I never missed it or bothered to replace it. That was 2004 :) There are a two ducts (grey corrugated pipe you can just see in the pic) that duct air to the filter. Its still crap, but meh. When i finally get my radiator setup I will fix all the inlet piping
The crossover pipe is gay because I was a tight ass and used leftover tubing from a pharamceutical project I was working on. It didnt have material certificates so couldn't be used...so i grabbed it for the right price: FREE :) Problem is its 1.6mm thick 316L so far heavier then ideal. But a breeze to weld
we all know you're a ricer Dave.
nice weld job on the cooler piping, who did the fab work for you?
I did that stuff for him from memory. It was ages ago but i think that was mild steel which was then painted black of some variety
:thanks:
Something like this this stuff yeah..cant be too hard to mount it..
http://www.thermalvelocity.com.au/Heat-Shields/Vulcan-Heat-Shield-/p-113-475/
Black Caliper paint comes up real good, needs no base coat..Did mine the other day..
Hope u have a safe drive home in the rain dude.
in gate vs ext gate td06l2
int gate 18psi ext gate 17psi
td06sh-25g on sr22 (nistune) low and high boost (red run is 14 sec pull so its artificially responsive) it was done to make sure det was 3-4degrees off regardless of load.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
