Spray the top side of the heat shield, might make it looks a bit better without the rust...
Apart from that looks like a tidy install :)
Agreed, it made mine look a lot better. Just black heat proof paint and i used some stainless allen key bolts because i'm a ricer.
Work in progress shot when i was fitting the 3071
Dori what paint is that man? I want to do my cooler pipes in a similar finish.
If anyone is interested my 10:1cr SR made 200.5kw @ 13.3psi on the mainline today, running a GT2860RS disco and failed VCT. Generally those turbos do 220 if everything is good, considering im using the stock AFM with a 40mm ID and the compression of the motor (dont forget its on a mainline) Im pretty happy with that.
Soon to find out how it drives when I pick it up from Jez.
thanks simon,
yeah im gonna spray it when i get a chance to hit it up with a wire brush and some rust protector first.
What gate, looks stock too meeee :ph34r:
Christ, I was hoping i would be able to squeeze in a std airbox with the high mount. Looking at that pic there is no chance.
Bugger pickling. Isnt even buying it a ball ache these days? Just linish the thing and remove any evidence of the weld. If you do the tig weld neat enough you only really need a bit of scothbrite. This is my gay ass old setup and the TB pipe was pretty quick and easy out of some stainless left over from work, a quick rub with some IPA and green scothbrite and you cant pick the welds
my intakes all aluminium..hence all the lobster, the weight savings are enormous
as for the gate pipe, we didnt have any mandrel 2 inch and didnt care
I dont mind cause when I put it all together you cant see shit anyways..
yeah thats right, I still have my stock snorkel bitches.... :nyaanyaa:
unfortunately though my crossover pipe is like 1mm thick rubbsih aluminium, welds sure to snap oneday..
Just need a cover for the gate and dumps now...prolly give some of that heat shield shit a go too..or maybe just some aluminum plate i dunno..
Hey Roy your gay ass old setup looks alright man Love that TB pipe..whats the dud pipe on the intake with a cap on it??
But wait... No CAI box, Isn't that illegal...You'll be sucking in hot air man, this may cause you to lose power and stuff.
Arent you handicapped enough with an RB20 :whistling: .
Man, your engine bay in MINT! I love it.
The dud pipe/cap is where the Greddy kit returns its BOV too. It has since been cut off and welded up. . The other pipe with hose in it is where my catch can plumbs back to on the street. The car once had a shroud over the filter, but it was pretty shit and when it went missing at the mechanics I never missed it or bothered to replace it. That was 2004 :) There are a two ducts (grey corrugated pipe you can just see in the pic) that duct air to the filter. Its still crap, but meh. When i finally get my radiator setup I will fix all the inlet piping
The crossover pipe is gay because I was a tight ass and used leftover tubing from a pharamceutical project I was working on. It didnt have material certificates so couldn't be used...so i grabbed it for the right price: FREE :) Problem is its 1.6mm thick 316L so far heavier then ideal. But a breeze to weld
we all know you're a ricer Dave.
nice weld job on the cooler piping, who did the fab work for you?
I did that stuff for him from memory. It was ages ago but i think that was mild steel which was then painted black of some variety
:thanks:
Something like this this stuff yeah..cant be too hard to mount it..
http://www.thermalvelocity.com.au/Heat-Shields/Vulcan-Heat-Shield-/p-113-475/
Black Caliper paint comes up real good, needs no base coat..Did mine the other day..
Hope u have a safe drive home in the rain dude.
in gate vs ext gate td06l2
int gate 18psi ext gate 17psi
td06sh-25g on sr22 (nistune) low and high boost (red run is 14 sec pull so its artificially responsive) it was done to make sure det was 3-4degrees off regardless of load.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
