Been reading this epic post for hours now and only got half way through it... But after all those hours of reading i noticed not one IW setup was documented, just the "dont go there" line was dropped a few times. Considering the price of these turbos, surely if your not chasing big power numbers wouldn't they be ok?? I only ask as i have already bought a TD06H601 before i found this thread and for the convenience of standard manifold placement and comp housing inlet size fits stock intake. I will be running this turbo with the following mods until i can afford a hi mount setup. Aim to run between 16 and 20 psi boost on RB25 Neo R34 GT-T. Hoping for around 250rwkw's, going to take it to Mercury Motorsport in Brisbane for final tune.
- Bosch 550cc injectors
- Walbro 255 fuel pump
- Return type FMIC
- Apexi PowerFC
- 3.5 inch straight through exhaust
- Z32 AFM
Once i have it all installed and tuned i will post dyno sheet for anyone interested. (3-4 weeks away)
Ebay link to turbo i bought - http://www.ebay.com....984.m1439.l2649
It will be interesting to see your reuslts, and you will probably be a pioneer in doing so. If you are willing to try it out then go for it.
Like ARTZ said probably 240kw tops, but it may feel pretty nice to drive in all honesty. Who knows, maybe you can be the one to prove they arent as bad as we have been making them out to be? Afterall its all theory based at the moment.
not a theory, trent has confirmed he's tuned a few of the IW ones and they were sh*t and couldn't hold boost.
Putting aside numbers for a second. Here is a 210rwkws Hypergear R33 GTS25t on good street/track tyres.(camera car). In fronf of him is an R33 GTS25t with a Trust T67-25G setup on RE55s. And in front of him me with my TD06-20G, I think i still had the std inlet plenum on at this stage.
So you have 210rwkws/street tyres chasing 310rwkws/semis chasing 260rwkws/semis. John in the camera car is a bit mad and with slightly quicker cars in front of him does a brilliant job of hunting us down, and murders us both under brakes...but you see the acceleration isnt worlds apart...and funniest thing of all...you dont see the T67-25G R33 get near my bumper let along overtake... :whistling:
I think this vid puts the numbers people sometimes chase into perspective. Would have been real interesting if the camera car had RE55s and had the same corner speed. But an extra 100rwkws means we do get away but we are hardly leaving him for dead.
yes ive had words to justin about that :P
1:36 is his best, i reckon there is another 2 or so in it, but GTST brakes are his down fall. Next track day im gonna passenger with a cattle prod.
Yes john is mad, super consistent, nice guy and needs a bigger AFM... or not i think he enjoys the flames.
I know this but the failures are not well documented at this stage. It could be that they work OK at lower boost levels. I doubt this guy will get close to 20psi before the compressor is maxed anyway.
What size is the rear housing? I cant open them at work but I think Kando only do 8 and 12cm jobs
Some hold boost...just dont make power... utter junk. We were around 20rwkw behind from 17psi onwards and 40rwkw odd at higher boost levels. Swap out the int gate housing to ext gate and magic happens...:cheers:
But they are cheap so what the hey.
well the story unfolds...the bits Roy didnt tell...
Roy has more experience...
John has massive brakes...
Justin needs shock therapy...
a rb30 series 2 block is what they call a A8 block or if you dont know what that is its a block with the oil feed and oil return and coolant feed etc for the turbo which are just blocked off with bungs. they were used in the late VL commodores i guess holden just wanted to move on the turbo blocks so people call them a series 2 block
FWIW, Aussie R31 had the oil feed / return on all models.
LOL...The whole point of the vid was straight line acceleration...not lap times. :nyaanyaa:
I don't know Justin , I spoke to him briefly on the day when I bumped into Trent "I grew a bear lately and am hardly recognisable" . On the day he was doing a smidgen under 1:38s and then at another day he did a mid 1:36 :thumbsup: Be real keen to see how the T67 goes with more runs...I was paying attention as I have that turbo at home :yes::)
As I said I don't know Justin, but with regards to John. Thanks for the using the word experience rather that slow...lol because I think its pretty obvious John is a quicker driver than me :angry:
Well i couldn't help myself after reviewing this thread again, so i sent kando dynamics a request to swap out my kit plus the differance between the kits and postage for an exchange on the T67-25G. Hopefully the exchange is accepted, as i havn't even recieved the original kit yet. 300+ kw with great reviews is just to hard to pass up i think... But thank you all for your feedback regarding the first kit.
Edited by swarzee
If any one has earned the title slow its me, im not even on the track yet, I dont even have a helmet...:laugh:
How many cars have you wrecked??
Thats the spirit :thumbsup:
Yeh, its bumpy as hell at the back under brakes....but the bigger problem is the gearbox fluid pissing out underneath the car and covering the underside of the car and rear tyres in oil :domokun: I should have known something was up coming onto the straight as the thing didnt normally wheelspin in 3rd gear like that :( But I simply didnt click and kept my foot into it.
Committed! :thumbsup:
Question for Trent (STATUS):
Do you believe the example shown for the 2871 vs L2 10cm to be acceptable as a 'rule of thumb' expectation?
The results you gave showed the L2 was just as responsive as a 2871 (am asuming .64 rear) and when the 2871 capped off at 250kw the L2 kept going to 300....
Am tossing up if I can expect the same from my own basic SR setup if I was to do a T3 10cm L2-20g with a decent manifold and gate.. The 2871 isnt too laggy when setup right (IMHO) but I am scared of how horrid a 10cm 20g might be on a stock SR.
Input would be highly appreciated :)
Kando Dynamics are willing to exchange kits for no extra charge, pretty happy with their service so far :thumbsup:
They do have good service, they have answered every question ive thrown at them and there also neg on the prices of there turbos. Even tho its "buy it now" auctions, Not that there overly expensive anyway.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
