Car isnt even in the same state as me at present. All is ready to go, just need to get my car back as its currently getting some fabrication work done. I hope its going to be a bit of a weapon at Sandown in late April. Will be on E85 with the whatever proves the best performer. If its the billet then hopefully makes power at 26-28psi. On EVOs they seem to love the higher pressure ratios so the lil 20 will be earning her keep. Would be nice to make 320rwkws with the 73HTA or 250-260rwkws with the 18G
Well, I suppose I have Datalogit so will just buy 200L drums of E85 and run straight E85 at the circuit and throw 98 tune back in for getting around town. Pain in the ass, but everyone else is doing it so the lap times don't stack up without it :( The cars running it just have so much extra grunt for free, its not a level playing field running a full weight RB20 on 98 :(
Nobody has said anything here but United have 100 back. My car makes an easy 10-15rwkws more with it so tempted to run a 50:50 with 100 United / E85 to try and get some mileage out of the 200L of E85.
Kind of relevant to this thread...
This guy is using 2 x td06SL2 20Gs on his engine..
if you are interested....
it is a 1GZ-FE - 5L V12
Auto box
In to Gen 3 Subaru Liberty converted to RWD.
Build thread here..
http://www.performanceforums.com/forums/showthread.php?67274376-Cracka-s-white-boy-shitbox-Gen-3-Liberty.-TT-V6-wouldn-t-fit-so-now-V12.
First start up vids on page 19 (not all hooked up yet but still...)
enjoy.
Mick_O is getting remarkably good mileage out of E85.
I drive 320kms to / from site every week + daily drive of about 30kms. I dont want to be paying for E85 and trying to source it. Hell, I may go a 91 tune :)
And replace your blocked injectors every 10,000ks lol
Honestly most family of mine who do not listen to me about the perils of 91 end up coming to me asking why their car runs like a lawn mower. Its ALWAYS a blocked injector, no matter how new the car is.
Just sayin' :whistling:
Have been running the EL wagon on 91 for about 8 years now. Never had a problem with blocked injectors.
My economy on E85 is pretty close to what it used to be on 98 as i only go for a blast here and there in my car as its not a daily driver.. Last tank of juice i got 410km with the fuel light on at 400km. Was spewing last week though E85 was $1.33 a litre most ive ever paid!
Yeah, TBH ive never had a problem with 91 in a falcodore.
91s hit list has been mostly nissan, toyota and honda. Pulsars, Corollas, Tidas, Echos, Celicas, Civics, that sort of thing and yes I have fixed a lot of bad injectors as a result of 91.
Either way I classify 91 as piss and think anyone would have to be stupid to use it in anything. Your call.
yeah i noticed the united 100, but i tuned with bp98 as usual i think, actually I dunno cause the fuel had been in the tank for 3 or 4 months before the tune so whatever I filled up with last, might have been caltex :unsure:
And people say fuel goes off...:no: so the united 100 is good yeah..?
Yeh, my tunes are not that line ball so when United have 100 I go to my 100 tune and just run 98 on the street. But when I go to the track I make sure I am running 100. Keep in mind 8 out of 10 drives I dont hit more then 4-6psi as I drive to attract as little attention as possible :whistling:
^ thats awesome mate thanks for sharing, helps me decide if i want one on my SR :)
Can you divulge the specs of that motor? Is it heavily moded or internally stock etc? headwork and cams? Thanks,
Also great to hear your getting back on the dyno today dori! cant wait
SR is forged with 260 pro cams with solid lifters. But tiny front housing is restricting power.
gday guys, thought id post my results from using one of these turbos
i have a tdo06 20g sl2 8cm rear on my rb20
turbosmart 40mm wastegate
550cc denso injectors
bosch 040 fuel pump
z32 afm
splitfire coilpacks
ebay spec front mount
3inch exhaust
Nisstune
still needs a little tweeking like a new CAS, decent front mount and cam gears are on there way.
cheers - trent
How much boost pressure? Looks like around 1bar from the figure. The cas holding you back? And what exhaust manifold?
Just trying to gauge if one of these is a compariable replacement to the trust item.
Cheers.
Cheers. Engine bay needs work as I have never cleaned it up properly after the fire. Plus loads of other small jobs where I just dont have the time as I am always away with work. Like ripping the dash apart on the drive up to Sydney over Xmas because my phone charger stopped working. So I cracked the shits and ripped out the centre console :closedeyes: Farking old cars...if you try to keep them tidy it never ends :nyaanyaa:
Im not sure about that, i think its the same as their 3" cover but with a 2.4" neck.
Thanks for sharing btw :)
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
