he isnt a large mainstream tuner like ADVAN/CRD etc
but probems were out of his control unfortunately.
i did ask jez to finish off the tune but he couldn't do it for the price my tuner quoted to finish (but ended up getting a discount after his stuff up initially)
he reckons 270rwkw~ as i said i wanted 280+ but he is doubtful.
and he says his dyno is low reading one, we'll see when i visit Jez and run it on his dyno to see the differences.
Correct. U paid for 90% of the tune already. So best for u to pay 10% to finish off the tune then another tune with me.
I would have loved to tune ur car. But i didnt want u to spend more money than u already have
U tuning with Unique Autosports in Seven Hills? They do a lot of 300ZX TTs - wonder why those fairlady Zs are so underrated - apart from a difficult engine to work on and overheating issues, they are a stronger base and in the 2JZ category I would say.
They don't overheat when taken care of lol.
Another highly underrated power monster i would place in the same category would be the Mitsubishi 3000GT or GTO...
^^ they are buckets honestly gearbox made of butter.... poor handling and hell heavy.
Cheers. Engine bay needs work as I have never cleaned it up properly after the fire. Plus loads of other small jobs where I just dont have the time as I am always away with work. Like ripping the dash apart on the drive up to Sydney over Xmas because my phone charger stopped working. So I cracked the shits and ripped out the centre console :closedeyes: Farking old cars...if you try to keep them tidy it never ends :nyaanyaa:
internal road rage.
Im trying to get my head around the million different turbo's these guys offer, also im still deciding whether to go high mount or use the stock manifold. What im after is a responsive street car with a power goal of 270rwkw.
Low mount choice, Do i go a a TD06H-20G in a IW with 12cm rear or TD06H (also 12c) with the Garret 60-1 Comp? Also IW?
Will the 12cm rear be to laggy?
High mount options i was looking at, TD06L2-20G 10cm or the T67-25G 10cm rear?
Im not fussed high or low mount, just want the best response, while reaching my power goal.
Cheer's!
Cheer's!
Hey mate, it definitely is a looonngggg thread with lots and lots of info, yet everything you want to know has been covered many times over.
Just to recap for you: we are only considering the TD06L2-20G 10cm or the T67-25G 10cm on an RB25 in all scenarios. The IW housings are a crap and arent stacking up even when trying to improve them.
You will need to run an external gate on an RB sized turbo, we recommend the tial 44mm gate as per SimonR32. If you are running a 4 banger you can go to the TD05H-18G in the SR20 spec housings, these do work and net around the 240kw mark.
For your goal of a zippy 270kw you should be looking at the TD06L2-20G 10cm with a small spacer and hung off the standard manifold. I recommend you hang the gate off the rear housing.
Alternatively, Hypergear has an excellent internal gate option called the SS1PU. It does not have the same 'scope' as the 20g (20g looks like it could be stretched to 300kw) but it does have the ZIP you are after.
Please have a read of this thread start to end, you will understand more than what you need to know to make an informed decision.
GTSCott, yeah thats him.
hes more known for his work on 1jz/2jz's.
so yet again, more problems...
his laptop fked up, he got a new one and it isn't compatible (or doesn't sync) to my haltech.
I would of thought haltach is compatible with windows xp/vista/7 but he says it won't sync, i just hope it isn't related to my ECU.
not very happy about this as it is all his fault. if only he tuned it properly from the beginning and is now causing a big inconvenience to me. so much for having it for 2 days only, except he rings me on Thursday saying his laptop failed, when i dropped it off on Tuesday. Just shows nothing was done until the Thursday.
nothing i can do now except wait...........
Mate, just ditch that incompetent tuner.. One problem after another. Time to move on. :action-smiley-069:
I'd get him to invoice for his time to date and move on. Doesn't sound like fun, id totally be pissed.
Then you can get son of rajab DVS JEZ to tune your Kando the great, and everyone's happy.
IMHO he owes you a refund. You have paid for more than you received and you cant have the car off the road forever waiting for him to resolve his own issues.
As much as its an unfortunate situation he should be willing to invoice for what he HAS done (not 90%) and refund the remainder.
If not 'do ma con cac i kill u' and see what he says then.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
