to close = touching?
its not touching 2-3mm room there
if I rotate the comp so the cooler piping follows the rail there's yeap's of room
the outlet is the widest part of the comp so it gives the least amount of clearance in its current orientation
Hello guys,
first of all i ask you nicely not to shoot me as i know what most of the answers to my post will be "use search'
Because this topic is 290 pages long with a lot of usefull information and also a lot of bullshit i'm going to ask a few question, because after reading about 40 random pages i don't have found the aswers yet.
To the point:
I'm currently building an rb20det for my r32, i'm looking for a nice budget turbo for ages! Everytime i come across this kinugawa turbo.
But i don't seem to find out wich i have to chose!
I'm looking for around 400HP (crank) and yes i've got all the supporting mods.
The key thing is i don't want to go cheap topmount or tubular manifold, so i'm stuck with the stock manifold (no discussion about this please!)
The downside of the stock manifold is restricting size of the turbo and INTERNAL WASTEGATE, wich seems to be crap on the kinugawa turbo's.
So finaly my question:
Wich turbo will FIT lowmount stock manifold? (fitting spacer isn't a prob)
Are the internal wastegate's really that bad????
Wicht turbo will give me enough power?
I really hope to get FINALLY the answers i need because i'm building this shit for 2.5 years now and deff need a turbo and get the car back on the road.
quick speclist:
Rb20det
Stock pistons and rods (used)
New oem piston rings
ACL main and con bearings
ARP headstuds
1.3mm cometic steel headgasket
ARP rod bolts
extended oildrive collar
ported head
rb26 oilpump with reimax internals
600cc injectors
r32gtr fuel pump
sard FPR
Greddy e-mange ultimate
z32maf
upgraded cooling etc.
stock manifolds
stock valve train setup
stock cams
Are you more interested in making the full power, or as much response as possible?
I personally am a huge fan of 16G6s on a stock RB20, at least if you are after a good usable power delivery - but the ones with the TD06 compressor cover, not the "bolt on" housing option. If I were doing a stock RB20DET on stock manifolds, this is personally what I'd go for: http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-Bolt-On-3-Anti-Surge-RB20DET-RB25DET-TD05H-16G-8cm-/271457770181?pt=AU_Car_Parts_Accessories&hash=item3f3424dac5. There is some debate on their flow, but I view them as an honest ~40lb/min compressor which should get you an honest "400hp @ crank" on a setup which is working well.
It'd probably be worth giving the wastegate port a little bit of opening up to avoid creep as they can do it, and it's not hard to take a bit of meat out of it - the flapper is big enough so cover a bit of opening up. I don't rate 18Gs from what I've seen of them, they don't seem to offer a worthwhile amount more flow than the 16G but lag increases enough that you'd hope for a worthwhile increase. Haven't seen any results of the billet wheel, but logic would have it that its going to be at least as good as the cast wheel given it's the same design with a little bit less hub area (ie, a bit less inertia, a bit more usable volume for pumping air).
stock gasket here with arp studs and close enough to 500atw. im sure stock will be just fine
that's the spirit - no point changing something that works well from factory..
if only our R32/33/34 all had yamaha motors.. 2JZ will happily make over 400kW unopened, stock cams, stock gears, stock everything really
if only our R32/33/34 all had yamaha motors.. 2JZ will happily make over 900kW unopened, stock cams, stock gears, stock everything really
Fyp.
Oh and yamaha only did the head
Fyp.
and who doesn't like head?
It proves they did it right, stock cams/valves and it's capable of 400kW+ (900kW according to zebrah) without any valve float business to worry about. If only Supras were more affordable I would be in one.. but sad reality is, they're not affordable.. at that price point I rather a GT-R because more tits
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
