massive compressor wheel to turbine flow mismatch
youll get massive lag from the turbine trying to drive that big comp wheel..then when it comes on, up top you will get power capped
by massive turbine backpressure from to small a turbine wheel
Area under the curve is the go, not a pretty number up top in the last 500rpm of powerband
Its just robbing peter to pay paul and will never work, especially on a larger capacity motor..
the t04z wheel doesnt work with the 3540 turbine, although lots of people have done it...its shitsville city..
cheers
darren
Well thats what I thought but stao said it will just make the turbo choke and is basically a waste of time. I thought a bilket hks 2871 would romp on the street on e85. In guiltoys thread he made 280kw at wheels on e85 and reckons he could of pushed the little 2535 even harder. So billet should kick ass even more I thought I even though to make the rear not choke bolt a kando t3 gt28 .73 vband rear on with a 38mm gate welded off it. Or even a 38mm gate welded off the hks .64 rear housing. Because the hks rears on the 2535's almost glow white hot when given a hiding. Not sure but maybe could even bore the internal gate out further to help flow a bit? Any thoughts.
cheers
darren
Cheers darren, much appreciated.
If you want response just run a .2 housing. :P
At some point the rear housing becomes a restriction and the gas speeds can't get any faster. As the smallest part of the entire system, that nozzle is the critical point. Too small and you will have great bottom end, to large and the top end will romp at the expense of low down.
Every rear housing is different and the nozzle isn't a particular size compared to AR, it changes depending on brand and turbo size. The HKS .64 is much smaller than the Garrett GT30 .64 for example, and was never designed to be pushing 300atw. Many have melted GTRS's at the track, and I am confident shoving a billet compressor which may flow up to 20% more air will only make it worse. Externally gated housing may help, but I haven't tried it on anything quite that small.
Yep apparently the flanges on the turbo were warping due to excess heat and the guy had to have the flange machined several times.
Edit: http://www.sau.com.au/forums/topic/405602-help-i-keep-warping-exhaust-manifolds-and-turbo-housings/
Edited by Super Drager
Josh the changes you're asking about are too extensive to worry about modifying the HKS/Garrett.
If you aren't opposed to running an external gate off the housing and want to try out a Kinugawa, try a TDO6SL2-20G, or have Hypergear build one with their 20.5G compressor. Response and area under the curve, and not ridiculously priced.
Yeah I In think ill stuff the 2535 off and maybe go what you just recommendon dale. External gate off housing is no problem. What powee that make pushed to it limits? Should just go back to the 6boob hi mount. To many bloodyoptions. Ultimately id love 330-350kw with killer response.
^^ And don't we all :yes:
Some of your other posts indicate going with E85. Not sure that the 20G would run past the 300kW mark, perhaps the HG 20.5G would go very close to fitting the bill. You'd expect pretty rapid response capability with either.
Once you start going with fabricated manifolds and custom modified versions of the Kinugawa you'd be mad to not look further. I'm referring to BW and split pulse options. Depending on model/spec they can be very cost effective (if a little more difficult to fit due to physical size of the unit).
Would thw borgy 7670 iwg need a custom 6boob made or just a standard work you think? That should make good response and minimum 330kw on e85.sorry to post this in the kando thread
20G will do 300rwkws on E85 easy. My RB20 made 310rwkws on 22ish psi on a dyno that certainly isnt known for high readings. So will make 310 on any dyno...with rather mega response on a 25
Josh - you'd have to chase an opinion from 6boost about what is needed for a BW. Look closely at the S200 range. From memory they have split pulse or open housings, using T4 flange. Perhaps get a thread going on the BW range, there's quite a bit on the 8374 but you are throwing ideas around about the smaller ones.
Troy - you have the experience in the area of the TDO6-20G so I'll yield here. 300-310kW is strong by any measure but not always that easy to crack. Fuel would play a big role with this combination I reckon.
There are Evos running up around the 400hp mark with the TDO6SL-20G on E85 but compressor flow/efficiency has got to be running out by then. Response/mid range should be the goal and one of these should make a decent account of itself.
Sorry, thought we were talking E85. On 100 i made 280 odd backed off to 270rwkws for track work. 98 was 260 for track work...on E85 made 306rwkws off the gate with boost falling off.
Another forum goer (Artz) earlier in this thread had the gate off the housing and std manifold on E85 that made the same power
Note how the 20G falls over on top end. This is from our re-worked version: SL20.5 mentioned earlier. It is made to have the same down low torque as the 20G, while holding the power band up top. Running against Kando's TD06L2-20G on a standard RB25det motor, Same response, more power with much wider power band. Nothing is changed apart from the turbocharger. Price difference is within $100 to listed kando item.
The red line was Pulp...and only at 1 bar boost for reasons I cant rememeber....
Staos turbo with the upgraded comp wheel is the go now tho...Would def of used that if it was available at the time
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
