Well Took it out for a quick spin at lunch today. Plugged in the ECU and everything started and ran perfectly! which is good news.
gave it a little bit up the main road and it has a bit more top end actually - infact in auto it shifts out of 2nd at 7,500rpm! pulled hard all the way and I was going over 120km at that stage so didnt want to keep the foot planted. It feels the same at low revs, mid range seems a little stronger (could be my imagination) but definitely pulls better up top and just keeps revving up to 7,500 - which is weird because the sticker on the ECU says 7,000 rpm.
Anyway I think I got a good bargain there!
Now its time for the high flow and dump so I can really make use of this ECU.
Good result Ben,, Sounds a lot like the Impul.
Got up close and personal with the new girl for the first time today.
After spending a heap of coin on stuff needed for a good hand wash at home I had mixed feelings, happy with how she sparkles but not so happy with the imperfections im finding on closer inspection - Kinda like some girls you get home from a night club, then see them under the proper light.....:O
Well after being busted and sitting in the garage for well over a month, I finally got the 260RS onto a car trailer and off to a mob that fixes gearboxes and diffs.
Entered some grass events in a local car show in November and she developed a knock in the front diff :rant: .
She will be fixed before the end of the month and be ready for SAU Putty road cruise!! :rofl: .
i would if it was between the 2 halves of the manifold but it looks like a real pain to get to
just want to know if its stock or not
also, i found where my leak is coming from, just need to work out how to get to it :-/
and i washed the beast :D
Edited by pipster11
another strange thing discovered on the stagea
~5-10mm spacer on the lower half of the manifold
anyone seen this on an rb25 before?
umm, that text that you have put the red box around says 'gasket'
yeah, and where there should be a gasket i have a 10mm thick piece of something
Probably a thermal barrier spacer, to keep your plenum nice and cool. :thumbsup:
I fitted one that Cam made under my plenum to space it up and fit the Deka injectors, 20mm of Bakelite does a very good job of insulating. The plenum is cold while driving now.
Back to back tested with a non cotact thermal gun, my plenum skin temp dropped from 82deg to around 50odd deg after I fitted the spacer.
It stops a huge amount of heatsoak from the engine, which has to add power, and the runner length increase definitely increases torque.:cheers:
i can't find any info about it on an rb25 tho which is odd
and the plenum is still hot because it still has the coolant lines running through the top half
and i'm concerned that its messing up the area into which the injectors fire
something along the lines of this, tom?
http://www.maceengin.../Products/MI612
looks very similar to that but looks more like bakelite (sp?)
has a rough/textured surface
- New Oil
- Oil Filter
- Spark Plugs
- Brake upgrade to 370Z / G37's
- Front windows tinted to match the rear
Now... I just need to get around to doing a highflow / dump / ecu / injectors / front mount..... ehhh >_<
Looks sweet once it's done eh?
On topic, Just bought some r33 GTS calipers for my povo front brake upgrade :whistling: Wil be getting the rest of my bits thru Conceptz tho'.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
