Well Took it out for a quick spin at lunch today. Plugged in the ECU and everything started and ran perfectly! which is good news.
gave it a little bit up the main road and it has a bit more top end actually - infact in auto it shifts out of 2nd at 7,500rpm! pulled hard all the way and I was going over 120km at that stage so didnt want to keep the foot planted. It feels the same at low revs, mid range seems a little stronger (could be my imagination) but definitely pulls better up top and just keeps revving up to 7,500 - which is weird because the sticker on the ECU says 7,000 rpm.
Anyway I think I got a good bargain there!
Now its time for the high flow and dump so I can really make use of this ECU.
Good result Ben,, Sounds a lot like the Impul.
Got up close and personal with the new girl for the first time today.
After spending a heap of coin on stuff needed for a good hand wash at home I had mixed feelings, happy with how she sparkles but not so happy with the imperfections im finding on closer inspection - Kinda like some girls you get home from a night club, then see them under the proper light.....:O
Well after being busted and sitting in the garage for well over a month, I finally got the 260RS onto a car trailer and off to a mob that fixes gearboxes and diffs.
Entered some grass events in a local car show in November and she developed a knock in the front diff :rant: .
She will be fixed before the end of the month and be ready for SAU Putty road cruise!! :rofl: .
i would if it was between the 2 halves of the manifold but it looks like a real pain to get to
just want to know if its stock or not
also, i found where my leak is coming from, just need to work out how to get to it :-/
and i washed the beast :D
Edited by pipster11
another strange thing discovered on the stagea
~5-10mm spacer on the lower half of the manifold
anyone seen this on an rb25 before?
umm, that text that you have put the red box around says 'gasket'
yeah, and where there should be a gasket i have a 10mm thick piece of something
Probably a thermal barrier spacer, to keep your plenum nice and cool. :thumbsup:
I fitted one that Cam made under my plenum to space it up and fit the Deka injectors, 20mm of Bakelite does a very good job of insulating. The plenum is cold while driving now.
Back to back tested with a non cotact thermal gun, my plenum skin temp dropped from 82deg to around 50odd deg after I fitted the spacer.
It stops a huge amount of heatsoak from the engine, which has to add power, and the runner length increase definitely increases torque.:cheers:
i can't find any info about it on an rb25 tho which is odd
and the plenum is still hot because it still has the coolant lines running through the top half
and i'm concerned that its messing up the area into which the injectors fire
something along the lines of this, tom?
http://www.maceengin.../Products/MI612
looks very similar to that but looks more like bakelite (sp?)
has a rough/textured surface
- New Oil
- Oil Filter
- Spark Plugs
- Brake upgrade to 370Z / G37's
- Front windows tinted to match the rear
Now... I just need to get around to doing a highflow / dump / ecu / injectors / front mount..... ehhh >_<
Looks sweet once it's done eh?
On topic, Just bought some r33 GTS calipers for my povo front brake upgrade :whistling: Wil be getting the rest of my bits thru Conceptz tho'.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
