well today i got the dump exhaust off..to fix the exhaust gasket leak.exhaust.. turns out there was maybe 1mm of the flange that WASNT leaking. When I pulled it off to fix it, it looks like the exhaust shop that did the exhaust did a dodgy, and shrunk the 3" to about 2.5" and put the stock flange back on (never taking it there again). Scotty the f**kn legend cut some of the exhaust off put it back to 3" with a new flange.. fixed.
Ok so made up a new gasket from Gasket material, with some gasket/exhaust seal. n put it back together..
it set.
Started the car.. i'de safely say about 50% of the turbo whine went away...sounds normal now..
still gonna take it to the turbo shop on monday to let him have a listen first..
once this all finished. i made some great souvlaki's and now im full and scotts so full he cant breathe!. goodnight Stagea owners.!
Glad to help.
You can cook those spicy souvos anytime mate, yum. :cheers: (sorry I know, you don't drink) :)
  • Like 1
I just get a black spray can and paint the i/c (just the front face) and piping black.
Isn't the stealth kit more expensive? Did they charge you the extra for it?
If not, I'd be spraying it yourself. Just use a satin finish.
did a service with Motul Chrono 300V + Greddy oil filter last weekend, i'm amazed at how smooth the car runs.
stewart warner boost gauge in, and reinstalled the foglights.
thinking about spraying the roof section between the rails gloss black - think it will look nice with the twin sunroofs tinted out. thoughts?
yes Ive always wanted a black roof between the rails, down the front pillars and over the bonnet
dayz S1 snow white.
and yeah the stageas Love the Motul 300v and Royal Purple.
anyone seen the 14point7.com widebands?
$100 for the controller, $50 for the o2 sensor
diy (basic soldering)
will probably be my next purchase (eventually)
also, mine is running pretty averagely, bogs down on cold start, feels very doughy, hesitating a bit :-/
i have a receipt for iridiums fitted about 20,000kms ago
i think i found it tho, someone has previously cut and replaced some of the wire going to the afm but only crimped it
so i soldered some new wire in and now it seems good :)
solder adds resistance to the wire, hence the crimp :)
Also on thin gauge wire, if too much heat is used, soldering can remove the annealing (which makes the wire malleable) from the copper and make the strands more susceptible to fatigue breakage.:thumbsup:
Edited by Daleo
Yep, just some Jaycar 5awg wire and some electrical ring connectors!
what do you ground?
as to the soldering, slightly higher resistance is better that random connections
i'll measure the resistance across it later
Recieved a box today containing my R33 calipers!
Got all the lines, shims and clips, and as a bonus what appear to be a virtually brand new set of brake pads :thumbsup:
Now for some offset brackets & bigger rotors...
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
