why was it a bad idea???
have you lowered it yet? your car sits even higher than mine :nyaanyaa:
Waiting on some more cash to lower it, Looking at just lowering the front..
Bad idea cause i got it back from my Installer and he explained everything bout the system, Has remote start which Cant be used unless car is locked, Cant be used when door is open, cant be used without handbrake on.. otherwise ill bugger up the starter possibly more. :down:
Pretty much was told worse system to put into an import. so ill be looking at changing it..... once lowered.
Whiteline sway bars F & R thanks to Chef :-)
R34 GTT brakes F & R
Rolled rear guards to stop scrub scrub from new wheels.
All in the space of 2 hours due to hoist and a full workshop........ :D
looks good :)
got a video of the sound??
refitted the cat today, and gave the pipes a quick coat of heatproof paint.
Edited by Big Fella
Was it because you didn't tighten it enough or because the line is split?
nah i tightened it, before putting it on, so that wasnt the problem, the join just basically wasnt sealing properly..
You didn't put PTFE tape on the JIC fittings did you? If you do it can stop the fitting from sealing correctly.
How much did you pay? The $500 ones with the foggies?
Going thru Streeter I hope...7% commission vs 14%
$114.thumbsup.gif No, I know the one you're talking about, that one was VERY nice, but I would have to paint anyway, so a couple of little marks didn't worry me. I've just got to fit some mesh in the opening.
Ended up using IM, as I spoke to Jesse last week; whilst his commission is less, his container cost was higher, and the end price was noticeably more on an identical part. I would definitely use him on Air Freight though, great to deal with.
Cheers, Dale
how much to make me a set?
all up pipes and stuff only cost $50, but i spent 4 hours welding and blending and grinding.
but that is only for the rear tips, you still have to make the brackets(in the right spot) and attach the flanges to both the front section and the rear tips.
The easiest way to make them up is on car, that way the clearances to fuel tank, tow bar, rear suspen sion and rear bar is all okay.
it would also be soooooo much easier to do 3 inch inlet into twin 2.5 inch tips. the next set i do will be like this. i'm making some for an r32 gtst and an s14 next.
I think any exhaust shop should be able to make them up and fit them for under $150.
I made a stainless set I sold for $250, back to the flange so he could remove and refit for track days etc. They came up great, not my thing (I like stealth) but the look is perfect. 3 inch pipes are the go, you just need to work out the merge.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
