car as it stands now.....shocking photo
BBS center caps are absent.....had a set of red/gold ones sent from overseas - and had the black ones off in preperation......they arrived on thursday and girlfriend accidentally threw them down the rubbish chute with a bunch of other rubbish before i got home.....devestated! new set on order :/
Edited by SMOKEYC34
I bought a new headunit, pioneer one with USB and Bluetooth for $200 cost it was last years one. Pretty happy with that one
I also have a word of warning to ppl thinking of getting alloy radiators, I don't think they can be cleaned like conventional radiators. Mine has blocked up and now heats up on the highway or going uphill for too long :( fml
:O
Lesson learned: ALWAYS get car parts delivered to work (dependant on work site of course).
Oh, and nice looking Stag! :)
:O
ALWAYS!(needed to be repeated)
my mum nearly put my GTR brakes in hard rubbish lol
thanks - it looks much nicer with the caps on and the front lip installed, but had to remove that - driveway entrance to the apartment is too steep and it scrapes.
next step will be vinyl wrap on the roof and mirrors, then detail the engine bay.
got maxima gas struts for the bonnet, and a radiator air guide to install this weekend.
Looks tough with those BBS; very nice.:thumbsup:
Time for G/f retraining.:whistling:
well, i decided to get stuck into my stagea exhaust once again,
i currently have a huge Jasma rear cannon AND a set of twin 3" blast pipes that i change between(jasma for long trips, blast pipes for fun)
But the car has been running the blast pipes for the last month or so and i have been getting sick of the massive drone at low revs.
I concocted a simple plan....make some bigger 3.5" blast pipes with hidden hot dogs.
Since i work at a Holden dealer i grabbed a couple of discarded VE SS hot dogs, these are 2.25" and are of high quality.
i bought a couple of short lengths of 3.5" pipe, and one larger length of 3".
Previously i have bought premade 2 into 1 collectors, but i figured i'd save some money and make my own
the 3.5" pipe was the exact same diameter as the hot dogs, which works well for stealthyness plan
i attached my homemade collectors, which still had to be trimmed up.
after a bit of smoothing with the angle grinder aand a flapper disc, they got a coat of heatproof black paint and were fitted up to my old rear section.
after running the car for a little while to bake the paint on i took it for a test run.
thecar sound exactly the same, maybe a bit depper, but my annoying drone is all but gone.
and it now pops bigger flames because my tailpipe area is retaining more heat :thumbsup:
You and your flames...
Looks great Robbie, you going to keep them on for the cruise?
definately, these ones have no more drone and a nice note, so they can stay on for good.
my jasma cannon is going to be relegated to the defect clearing section of the shed :whistling:
Looks great man. Excactly what i was going to do.... Are they 19 x 9.5 +22 (per chance :whistling: )From a guy in Brissy??
Note to self: Don't drive behind Robbie on the next cruise!
the stagea got a fresh sump full of oil this week, the new exhaust, some fresh tyres and a wheel align.
And i finally pulled the centre of my dash apart to fix some rattles and re-route my ipod and av connectors to the centre console.
It turns out that the little tray under the lid is the perfect size for an iphone or ipod :thumbsup:
On the hunt for an immobiliser. And desperate to get it on ASAP due to the recent mass car jacking that took place here in Canberra the other nite. FFFUUUUUU!
I got one of these from an SDU group buy from the US:
http://www.yulontech....asp?infoid=122
It provides location if the car is moved out of a set area...(will send you an sms message with its location) or you can phone it to ask for its location. You can immobilise the car remotely with your cell phone etc etc
was on the Monash Fwy today behind a truck and something fell off it...I had no chance to dodge and it went under the car.
Made some loudass bangs.
Now when I accelerate hard my car makes clicky/rattling noises...great >_<
Checked under the car and now I have 3 bigass dents in the exhaust system...farrrk.
Dropped the oil and topped up with Motul. As usual the filter was on too tight by the previous guy who did it (RVO auto) and I had do the whole stab the filter with the screw driver thing...made a huge mess...arrgh.
also raised the rear suspension by a few cm...hopefully that'll minimise anymore scrapage...
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
