Still not sure where I want to take it, everyone says go to efi but their prices are a bit high, I've had bad experiences with recommended tuners before, the people with no recommendations are always more willing to fix their mistakes.
That's if your engine survives their mistakes!!! Do you want to risk a $10,000 rebuild for the sake of a few hundred dollars? The tune is the most important element in the process.
i see your point, judging by how its running now it will only need a quick touch up anyway. im gonna give efi a call tomorrow and get it booked in. just a question, ive never had a car tuned that didnt have a boost guage, should i temporarily install the one from my wifes car for the tune??
My cars tuned and it still doesn't have a boost gauge
:P
I attempted to help Brad install my headrest monitors, we got them all in and got the headunit fixed up. Now we have 4 screens running for our trip over to Melbourne for Gymkhana :thumbsup:
Brake rotors were finished and sent Friday, so just waiting for them to arrive and fit up. Waiting for lots to arrive at the moment...
Want to do mine? I'm so bloody lazy...:rolleyes:
bit of a prick to do but luckily cos i have the plenum spacer i didnt have to take the inlet manifold off too :)
about a 3hr job taking my time to do it carefully.
disconnect all the wiring around the left bank.......... because i disconnect the cam sensor is that going to cause a drama when i go to start it up again ?
Yeh, I've got the spacer too.
I'll be doing mine this week I think. You shouldn't have any issues with engine light as long as you don't turn on the key with any wiring disconnected.
4? where's the forth one mounted?
How hard is it to do these headrest screens? how do you run the cable through the seat?
I have the standard one in the dash, and the 7" pop out one in the headunit. Plus two in the headrests.
Headrest screens aren't that hard, but I sucked at it. Brad was running wire through the seat backs, because there is a void in there, but I sucked at getting the wire through the seat, because there's the metal frame you have to work around.
You need patience to do it, and I don't have enough >_<
I've got a mate who works at Tower Audio who'll do it but he's pretty busy. Not sure if I'm brave enough to attempt this myself...
Might just stick with wifi streaming for the time being
Don't you just unzip the cover at the back & lay them in? Anyway,that will keep the passengers entertained.
And you have a heap of stuff coming if I recall - you are going to be a busy lad over the next little while.:happy:
Apparently they're a pain to rezip and resecure, so we used wire. Not too difficult really, just have to be patient threading the wire through.
Yep, big collection: Rotors, braided lines, shift kit, BCs, wireless reverse camera being the main stuff. Also got pads, adjustable rear toe arms and Informeter which still haven't made it in. Looking forward to getting it all installed :thumbsup:
Headrests are not that hard to put in. Like Ryan said you need patience. I fed a banana shaped bit of wire down the back of the seat. Some times you get it first go other times I just want to throw tools. And if you unzip the seats and undo the plastic lip at the bottomm its a bitch to get back together.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
