swapped the transmission over yesterday with the 'good one'
big thanks to craig (jetwreck) and andy (andy65b) for their assistance.
the box is pretty much the same, just lacks that overdrive lockup problem which was a massive pain in the ass.
cant wait for the shift kit to go in!!
I hate the way the convertor clutch locks up so early. Previous jap nissans I've had they don't lock until your over about 85km but the m35 seems to lock at about 60km or lower.
Edited by slippylotion
+1.
Around town or anywhere up to about 90km/h, I flick the stick across into 4th; locks out top gear and is generally a bit more responsive.
Doesn't kick down as easily, but I don't find it too much of an issue; much better than constantly shifting up and down all the time, because you can't maintain 70km/h...
I disconnected the torque lockup two years ago, The high stall converter keeps revs up over 2500 when cruising and shoots up to 4k fairly quickly once boost kicks in. I pay the price with less fuel economy though, I still need to fit a switch near the gearstick to lock the converter on long drives.
Speaking of overdrive, is it just me or do these things want to be in 5th gear asap. Cruising at 60kmh in overdrive at 1000rpm seems kinda stupid..
once the box went into lockup, if it was in it long enough it wouldnt come back out of it
and yes they get into 5th quickly, but i find now if i move my foot a little it will kick back no problem.
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Hey Ross, what exhaust did you put on? And I like your wheels - car looks great mate.
Picked up my autech on Sunday morning and fitted some 20" rims I had laying around straight away lol. Hopefully getting front pipe, highflow cat and and 3" cat back fitted this week
we want pic's!!! :P
Thats a good time.
1st owner of my stag (CoolPC) ran a best time of 16secs, with catback exhaust k&n pod filter & 10psi
Would love a strip in Sth.Aust to see where it'd be nowadays.
Once the engine is refitted, of course.
$4k is the rebuild price, including engine out/in, tune after run-in, CP piston kit, complete block work (bore/hone, acid bathed, etc), head refresh & new MLS gaskets.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
