swapped the transmission over yesterday with the 'good one'
big thanks to craig (jetwreck) and andy (andy65b) for their assistance.
the box is pretty much the same, just lacks that overdrive lockup problem which was a massive pain in the ass.
cant wait for the shift kit to go in!!
I hate the way the convertor clutch locks up so early. Previous jap nissans I've had they don't lock until your over about 85km but the m35 seems to lock at about 60km or lower.
Edited by slippylotion
+1.
Around town or anywhere up to about 90km/h, I flick the stick across into 4th; locks out top gear and is generally a bit more responsive.
Doesn't kick down as easily, but I don't find it too much of an issue; much better than constantly shifting up and down all the time, because you can't maintain 70km/h...
I disconnected the torque lockup two years ago, The high stall converter keeps revs up over 2500 when cruising and shoots up to 4k fairly quickly once boost kicks in. I pay the price with less fuel economy though, I still need to fit a switch near the gearstick to lock the converter on long drives.
Speaking of overdrive, is it just me or do these things want to be in 5th gear asap. Cruising at 60kmh in overdrive at 1000rpm seems kinda stupid..
once the box went into lockup, if it was in it long enough it wouldnt come back out of it
and yes they get into 5th quickly, but i find now if i move my foot a little it will kick back no problem.
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Hey Ross, what exhaust did you put on? And I like your wheels - car looks great mate.
Picked up my autech on Sunday morning and fitted some 20" rims I had laying around straight away lol. Hopefully getting front pipe, highflow cat and and 3" cat back fitted this week
we want pic's!!! :P
Thats a good time.
1st owner of my stag (CoolPC) ran a best time of 16secs, with catback exhaust k&n pod filter & 10psi
Would love a strip in Sth.Aust to see where it'd be nowadays.
Once the engine is refitted, of course.
$4k is the rebuild price, including engine out/in, tune after run-in, CP piston kit, complete block work (bore/hone, acid bathed, etc), head refresh & new MLS gaskets.
Spent about 3 hours scrubbing away at the double sided tape/foam that the japs must have used for aerials. Unfortunately the previous owners never bothered to remove them so they were pretty much rock hard.
Also debadged the rear end.
Going to get some quotes on how much to spray my wing black/spray my new grille and fix a small dent in the passenger door and most likely respray the bonnet tomorrow. Previous owner did some "touch ups" that most people would refer to as graffiti. I'm hoping I can get away with all of that work for under a grand. No idea though..
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
