The Stagea made 335 rwkw at 25 psi last night with the new sound control exhaust. Very interesting to drive now, especially in rear drive. :cheers:
Well done Scotty. And I mean it ( you know when people say well done to someone just paying $, insted of actually building the car-like you have!)
Interesting final figure. I heard 328 @ 20psi from you know who last night.
Do you think that there is a restriction- as 5 extra psi didn't net much gain. Have you found the limit of the stock manifolds? Its not the Exhaust...
Or on the other hand, was it made a bit safer in the tune?
Dyno graphs please!:thumbsup:
Nice work Scotty! You've got a lot to be proud of with the development of your car.:worship:
Must be a hell of a thing to drive now!:thumbsup:
E-manage back in and running
One last tune......I wont catch the Scott's figure.....but hopefully will crack the 300AWKW's!
Craig, you sticking for 98 for 300kw, or switching to E85?
Scotty, great figures. Since it was measured in RWD, is it likely to drop when you get that front diff in, in terms of awkw?
sticking with BP98......cannot be bothered with E85.....I should have more than enough power for what I need or want.
I'm not really aiming 300AWKW's.......250AWKW's should be more than enough for what I want.
Took my car to Hampton Downs yesterday - best lap of 1.24.22 with 240kw.
Hopefully will have around 300kw next time.
Anyone who hasn't tried a track day should give it a go - great fun to be had hammering it flat out without fears for your licence!
A brake service with front discs machined and new pads all round..
Give the car a good clean and my much loved car will be for sale. :(
stay tuned for sale listing.
Are you getting a Series2 ready for the English conversion
Fitted Whiteline camber bushes a few years ago now due to the usual rear tyre wear issues. Was still chopping out rear inner tread (though not so bad as initially) so I have now fitted aftermarket rear adjustable links (upper) which should solve the problem permanently. One small hiccup in the process of removing OEM camber links, only the outter camber bush had been adjusted. The inner bush was set at (nothing, not used, set at minimum) :angry: What I don't get is that the knuckle heads that did the alignment fitted the bushes so it was not as if they were unaware of full adjustment facility.
Oh well, onwards & upwards now :turned:
GW :miner:
After nearly 2 years of owning the stag i finally connected the automatic headlight adjustment plug... the retard compliance guys filled the plug with silicon when they removed the HID lights.... does anybody else use this fearure?? Its a S2 by the way
I finally got around to fitting the radiator fan shroud, not much left of the radiator mounting side as the radiator core is so big. Also re-installed the Mishimoto 62 degree thermostat while I was there. Hopefully no more overheating issues in traffic.
Automatic headlight adjustment? Mine just has an adjuster switch so I can set them as high or low as I want.
Yeah thats what im referring to... its automatic opposed to popping the bonnet and adjusting with a screwdriver :)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
