I've never had an issue with my stock xenons
gotta love it when they leave everything be during compliance (was done way before i bought it tho)
back on topic
apparently i have a new battery, definately regretting leaving my car in qld and taking the smelly r31 to tas
Cars at boostworx, getting bigger fuel pump, high flowed gt30/76, 1000cc injectors, 200 cspi? Cat, z32 afm, yellow jacket coil packs retune of the Nisstune. Next Tuesday car is booked in at mv automatics for shift kit. Oh and I'm getting them to lower my car via coil overs. Can't wait till Wednesday Thursday night to get it back.
He has been reading and I believe he will start posing soon.
Cheers
Andy
Not sure if that was a typo or intentional, lol. Posting soon?
Sold quick Andy. You must be both pleased & a bit sad :( .
I put GTR struts with king springs (low/-25mm) in the front of the car today. the ride is a little less crazy now and a bit softer,
i think this will turn out to be a very good value suspension mod, total cost $350 and 3 hrs of my time to fit them.
New wheels
Looks good mate thumbsup.gif; sizes and offsets?
Looks like you need some new snubber rubbers for your fuel door. Nissan P/N; 78837-AG000.thumbsup.gif I think they were about $5 for the pair.
Hope this isn't too boring for some people...
My fuel doors the same. Thanks for the info on part numbers. Great looking ride there. Have to be proud of that....sleek
Hello all. i have to say all your cars look mint! and thanks for all the info iv found on these forums. i got my stagea (m35) the other day done few mods to it so far hks evc (son of a bitch to use at first lol),hdi intercooler,nismo suspension etc.. going to be putting in a HKS F-con v-pro next week and exhaust still on its way from japan :P
More F-cons, love it!
You in Aus or NZ? Getting MAP sensor and temp sensor fitted too?
I really need to get mine installed...
Nice Dale, who is doing the Fcon install? Did you manage to find a harness?
You will find no matter what you do boost will drop off after a midrange spike, I can send you an uprated actuator if you need one to remedy that. You still on the stock turbo?
haha. yep im in nz St hi-tec are going to install for me with all sensors and a dyno tune. i plan to put in a garrett GTX3071R at some stage stock turbo runs outa puff!! need more power! :woot:
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
