Hey Leon, I have some good news regarding your oil leak mate; check PM's :D
I'm a little reluctant, as I will not take money out of Scotty's pocket on this one. If Scotty is ok with it; I may look at it.
The other issue is as Scotty has said; this one will not support maximum power, and you'll need to start again if you want to shoot higher than the 240odd kW mark.
Thanks Dale, that oil line should fix me up nicely. :cheers:
Fair enough on the intake production, but that power level would satisfy most guys (those that didn't want to go down the F-Con / Emanage path). Whoever decides to make them should get quite a few orders.
I'm not worried mate, yours looks the goods if you can replicate it on the bench. It's only replacing the lower part anyway and requires you to use the stock rubber pipe right?
Personally I hate that rubber U bend (flow would be woeful) and decided to fabricate the whole intake in 3 inch, as the inlet of the turbo is where massive gains can be had. Obviously this only works if you have control of the ecu as Leon said, due to afm cut and requiring more fuel.
Ok mate; yeah it's not too complicated to reproduce in a jig, looks like I might have to fine tune it a little if there's a few to make.
It does use the rubber pipe; but it doesn't have to. I just needed the bottom section first up. I'm going to make the top part, then see how it goes.
Yours uses that extra diameter effectively as a "plenum" for the turbo, which has a couple of benefits; not the least of which is a big improvement in response.
If thats the case Dale, why did you do it in 2.5"?
Just to avoid afm cut?
Because it was still a huge improvement over the stock piece, and I knew it would fit through the gap left by the stock piece.
A 3" version will not fit through that gap, and requires a 3" to 2.5" reducer off the flange, along with being much more problematic to route due to it's much larger diameter.
Standard mandrels are not tight enough to use; so you must either cut them tighter, or "Lobster Back" straight tube into tighter bends.
To fit the equivalent of 3" cross sectional area through there; would require fabricating a 2.5" version, then splitting it through multiple planes, then filling the gaps with sheetmetal and purge welding all over again. A lot of labour; a lot of cost.
So it wasn't going to be a simple afternoon's work.
Avoiding the AFM cut was a rather happy coincidence; I didn't really want to trip over it, because I can't tune around it yet, and I'm almost at the limit of my injectors.
Sometimes you're lucky; sometimes you ain't. This time I was.
Not lucky, moar flow required mate. lol.
On this topic, those of you with the stock computer should be fine but if you run a Nismo, Impul or similar you should really chuck it on the dyno to make sure the injectors aren't maxing out. We don't want another Jetwrecker incident... The stock ecu has that fuel cut for a reason...
I have done a bit of wrapping of the centre console, door pulls and rear upper tail lights. Install DRL's, LED parklights and swapped the Transmission tiptronic shift pattern to forward down, backward up a gear. Installed Nismo Springs lowered about 30mm.
Edited by 0t1
Hey, the carbon wrap on your console looks sweet.
Was it difficult to get looking OK?
I have been looking at the terrible woodgrain in my Mrs' Maxima with aesthetic sadness for quite some time and this might help.
Even it was just black with a less defined 'weave'....
Edited by shane344
I've been customising and building cars since ages ago, This was my first go at doing wrap vinyl, it will be better as there are bits I can notice that aren't good enuff and I will redo soon.
I removed all the parts to be wrapped, and used a hair dryer, as the heat gun was far too serious.
I will wrap the roof as I intend to put a roof rack on as well.
The wrap comes in carbon white, silver, black, charcoal, red, yellow, gold I think they have colours covered, and then there are normal colours and even change colour stuff.
I put it on because I had ordered the car with a single DIN for a NZ stereo and the facia was grey and did not match the brushed silver alloy of the
Not "my" Stagea per se; but in any case.
Flange is only tacked in this one as we needed to do a test fit prior to finish weld.
Fitted perfectly (once we had some tools)
And baking prior to ceramic coating.
Edited by Daleo
So I did an oil change in preparation for this: http://www.skylinesaustralia.com/forums/topic/402815-sauwa-skid-pan-day/
After having my car now for 25000 Kays and getting it serviced by pros to hopefully find any major issues I have confidence in the car now...
I no longer have confidence in mechanics though, my sump plug was finger tight, i just touched it with my 14 and it moved....
Explained the drips on my floor.
Also made an RB rookie mistake and spewed oil on my floor getting the oil filter out.
I thought I had it but my hand got jammed on the way up,
Spent another 20 minutes trying to clean up the front diff and steering rack while the kitty litter did its job on the floor..
Also also I know believe the service turbo cars at 5000 mantra.
The shit that came out of my sump after 8000 was like coal.
What oil were you using Shane? Should have been fine if you used a good quality oil.
Also made an RB rookie mistake and spewed oil on my floor getting the oil filter out. I thought I had it but my hand got jammed on the way up, Spent another 20 minutes trying to clean up the front diff and steering rack while the kitty litter did its job on the floor..
It will always drop oil on the diff and rails....always.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
