Correct, no use going to a DYNO unless you have a method of tuning.
However, reset your ECU so you can more easily feel the difference made by the exhaust, rather than waiting for it to adjust slowly as it learns.
The 25G was driven out of the garage yesterday. It has all its bits on. I am going to call him Joseph. Silver guards, white bonnet, S2 rad support and when I get time a red rear bar.
Have completed all the paperwork to pursue the matter for costs, it goes through QCAT here in sunny Qld, which has replaced the Small Claims Court. When and IF I get a settlement I will have it "refinished". I think that is newspeak for respray.
Thanks to all the guys who helped This Forum has saved me heaps over the years.
Cheers, Hugh
Cheers, Hugh
This post is useless with pics!
Show us Joseph!
Cheers, Hugh
Anytime. Glad to hear it's out of the garage.
On Friday, I decided to remove the foglights mounted on the bumper as they are just slowly getting stonechipped and I never use them.
After removing the front bar, I was shocked to see that my front reo bar was damaged. This was damaged when I got reversed into, and was not replaced by the repairer. I have taken photo's and will contact JustCar and see what is the go from here.
Anyhoo, I have always been interested in where the AC get's it's outside temp reading from but could never find it. Well I found it while the front bar was off didn't I and I moved it ! But to where you ask ? no ? ok fine....
Well I want to know what the air temp is my engine is sucking in so I placed it right next to the air filter.
The only thing I can think of as a downside is that the Auto AC setting will be going off that sensor, but i even have plans to get more of these temp sensors, wire them all in earthed to a rotating or multipole switch and then I can choose the sensor and push the button to see the readout :D All will be sweeeeeet
Oh and I painted my grill black. Ugly grille still ugly, just black :D
You can see the damaged reo bar on drivers side, and i also brightened the air temp sensor location
New position of air temp sensor
Tadaa
Looks good mate ^^
Put in new platinum plugs and hardrace adjustable castor rods. More response with the plugs and much better steering response with the new castor rods. Will be doing new rack ends and tie rod ends soon along with slip on lock spacers as the stagea can't turn for shit. Already smoothed off the steering knuckle knob which made a big difference with lock but the rack is out if travel so these spacers will help. Cv joint angle looks ok still while spinning which is my biggest concern.
Thank you Davey. CV angle is a concern of mine too with the amount of k's I do. I recently just put in bcpr's and tapped em to .8mm car runs so crisp. Will look into platinums though for next change. You are spot on about the hardrace adj. castor rods. They are indeed the next thing I am purchasing handling wise. I unfortunately know nothing about "smoothed off the steering knuckle knob" so I will look into this. Do you have any more info on this and the slip on lock spacers etc ? I will go searching now :D
coppers give better spark than platinum
iridiums come close to copper but with the service life of platinum
also, that black grille looks pretty good
i might have to get some plastiwrap and do mine similar to that
i love how even the reo is yellow lol
Oops I ment the lock stops. Grind them off the steering knuckle. I am taking a guess and got the slip on lock spacers from GKtec to suit Nissan. Should be the same as silvias/skylines
I changed from .8 to 1.1 may have some difference?
First oil change since new turbo went on, and fresh oil in both diffs.
Diff oils came out very clean, but both magnetic drain plugs had a decent amount of filings; possibly not cleaned at last interval. :unsure:
Wats new in my stagea life. Well just got home from picking up my second stagea. The auto my fiancé will be driving. So those in adelaide if u see her don't hesitate to wave. And I have just purchased a manual one. Pics will be up when she gets a clean. And then I'll be looking into wheels for the new girl :)
Yea it's a s2 rs4s. :) and yea looking around but thinking more akin lines of 9" rather the. 9.5" but I'll see Wat I can afford at the time. As not going cheap
18x9.5 +12 for the manual stagea (assuming c34)
/wheel dimension dilemmas
Seems to be the perfect fit for a stagea!
Has anyone had problems with these size wheels and hitting the front inner guards? (When lowered)
a set of rota wheels will set you back around $1k + $500ish for tyres in that size for some cheapies
in a 9 you'd want something like a +10 but anything around there will sit well
I run 18x9 GTR wheels with 235/35/18 tyres and they lightly rub the inner guard liner at full lock. Not enough to worry about though
your an auto are you not duncan, so you'd be pretty flush on the rear but inset on the front, going from a +30 (stock gtr offset) to +12 would probably make it flush and stop the rubbing
in other news, i just ordered a cusco rear strut brace and a mate should be picking up my new front sway bar for me soon :)
Then i'll only have to wait till mid november to drive my car again, getting pretty bored with just driving the gf's R31
Spent an hour or three pull off bits to get down to the knock sensor in the V of the block in my ARX. Computer attached to car to diagnose why it was running very rich and had retarded timimg came back with - "faulty knock sensor". Was assured by mechanic it was definitely faulty not a loose or otherwise bad connection.
Have a look at the attachment and you will see a nest made of firewall material and chewed conductors. The mouse trap is artistic licence.
Thanks to Scott I found my way down to the problem and now know a bit more about how it is put together. Hope not to have any left over parts when it goes back together tomorrow - once I repair the cable.
Edited by Old Gregg
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
