redo
garret 35r turbo
new thicker cooler [unsure of brand]
full 3.5inch stanless turbo back exhaust pipe
750cc injectors
Tomei poncam camshafts
and a retune
video
http://s1160.photobucket.com/albums/q494/r33huntme/?action=view&current=stagea002.mp4
Spent an hour or three pull off bits to get down to the knock sensor in the V of the block in my ARX. Computer attached to car to diagnose why it was running very rich and had retarded timimg came back with - "faulty knock sensor". Was assured by mechanic it was definitely faulty not a loose or otherwise bad connection.
Have a look at the attachment and you will see a nest made of firewall material and chewed conductors. The mouse trap is artistic licence.
Thanks to Scott I found my way down to the problem and now know a bit more about how it is put together. Hope not to have any left over parts when it goes back together tomorrow - once I repair the cable.
Looks like the sheath on the coaxial is cut at the plug end, joining it back should be enough but re shielding it would be best (somehow). Let me know if you want the spare knock cable expressed buddy.
Hahaha... Your not the first, and won't be the last to have a mouse nest in the valley. Pesky buggers.
My neighbour had a fire in the engine bay of a Camry the nest was built on the exhaust manifold.
redo
garret 35r turbo
750cc injectors
and a retune
video
http://s1160.photobu...t=stagea002.mp4
Have you got a plot with boost. I guess you have 260 deg poncams?
I didnt open the rest of the cable up enough to see it as coaxial. From what I can tell the black insulated cable is the core. The other seems to be the shield conductor but it is bundled in clear or pale coloured insulation for that last 5cm or so. For that last bit outside the flexible conduit it just looks like 2 insulated conductors, same colours at the other end. You can see a bit of the other conductor left at the plug and the cable
Thanks for the offer I will see how it goes. Only problems may be, the quality of the solder joins as was hard to get the conductors to "tin", and the tolerance of the insulation to the heat. I may have made the cable a few cm longer so that may have a impact as well. Feels like normal again driving, will see how the first tank goes.
Maybe there should be a rodent modifications topic?
My rodent nest was made from a 100mm by 100mm area of the fire wall insulation so at least it couldn't catch fire.
Installed a Koyorad full aluminium radiator, two 12'' davies craig thermo's with temp switch and custom aluminium shroud, big trany cooler and transgo shift kit to my M35 ARX over the weekend. Radiator is excellent - thermo's only need to switch on while idling after some time or high temp days every now and then. Radiator is so much more efficient. Transgo kit is absolutely fantastic!
Nice! Did you do the Transgo install yourself?
There's a nice controller on eBay for about $100.
Had a bit of fun today; started out bleeding some air out of my cooling system, and once I'd finished, dropped the bung for the rear bleed point down the back of the motor.
Ended up having to crawl halfway under the car to fish it out of the rear undertray...
I've also been waiting a week or so for my new HID globes, as one blew. Globes turned up this arvo, so I thought; why not?
Passengers side done, had to pop the airbox out, but no biggy. On to the driver's side, pulled out the coolant recovery bottle; globe changed, but I was using a torch by this stage.
In went the recovery bottle, and straight down went the torch.
Did it drop into the undertray? Nooooooooo; of course not! Hit the undertray, and bounced up and magnetised onto the top of the oil filter...
Had to drop half the undertray in the garage to retrieve it.
TL/DR?
Took 2 simple jobs, and turned them into epic displays of hamfistedness.
Farkin hate cars sometimes.
Edited by Daleo
^^hmm reminds me of changing the battery but dropping the wing nut and having it lodge/wedge itself behind the radiator necessitating loosening the top bolts and lifting the radiator up........but first spent 15mins shaking the undertray and looking everywhere for the bloody thing.
Lucky mate, I dropped mine in between the heatshield and the exhaust manifold, I had to leave it there.
I now have a ball valve at the bleed point, it makes purging the air simple with a funnel screwed in. ;)
Originally, that's where I thought it had gone; much swearing was done.
I saw pics of your setup; do you find the branch into the rear of the block simplifies bleeding?
Feel like making one for me? Price?
Hahaha... Number of times I've been saved by one of those extendable magnets when dropping stuff. Best tool for oafs.
One I couldn't find on the shitbox, was a tps clip. Sprung off never to see again. In that case cable ties ftw.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
