It was pretty straight forward as per the write up i got too much hose as well though.
did the initial bleed last night, bled it till no more bubbles. but decided to do it again this morning with some light!! and it was just trickling coolant out of the valve with no bubbles.
i think it will be a very good mod to have letting all the coolant flow through instead of it sitting behind that plate..
thanks mate
All good things come to those that wait, and tonight Andrew at AM Performance posted pictures on Facebook of my new intake.
post-34363-0-90270300-1354098789_thumb.jpegpost-34363-0-19941200-1354098808_thumb.jpeg
After originally thinking he'd need to make two versions, one for the airbox and one for my pod, Andrew ended up making one that suits both.
I'll be giving the whale her maiden voyage tomorrow night, and if everything goes well Andrew has a jig ready to go.
It's been a long two weeks but looking forward to driving Moby again! And not having to drive a mint green automatic Barina with pink seat covers anymore...
So, how does intake length impact performance?
More length (plus corners) would cause the air to take a few extra milliseconds to reach the turbo - that can't really be a big deal, or can it?
The reason I bring it up is that my intake would be a foot shorter....
Mate, there's no doubting it'll be sooo much better than the stock one. The question of length was simply me contemplating the universe, physics & automotive engineering (3 things I know pretty much nothing about, lol).
Interested to see how it goes Ryan, at what point along the intake is the reduction to 2.5"?
Leon, The extra length is additional volume effectively a "Plenum" area that the turbo can draw from, which doesn't hurt performance at all IMO.
I'm with you here Leon, don't know anything so relying on expert opinions! :P
Dale, Andrew has photos for me tonight so I'll be able to confirm, but apparently it steps up pretty much straight away from the turbo, but I wasn't aware the intake on the turbo was only 2.5".
The old plenum in the intake trick (you have to say it like Maxwell Smart).
So if I route mine to the rear & back (8m) I'll get extra performance? See, now I'm being silly :P
Somebody had to take it too far, didn't they?
ever tried to drink through a really long straw???? just my thoughts.......
Car is back. Couple of things to fix before the SAUSA cruise on Sunday, but I'm confident it'll be right, and I'll be able to properly test out the intake.
After driving the car out of Andrew's workshop, I left it warming up, came back to find temps up to 120! Discovered it had dropped close to 5L of coolant - which doesn't sound like just the leak at the back of the block.
Topped up and temps seem ok - about 94 idle after 5-10 mins, but remember it's been close to 40 degrees ambient in Adelaide today, and wasn't much better tonight. Seems to be bled properly now too (although I thought it was before).
As for the intake, what a work of art. Andrew's work really is top notch. I asked him about the shape and it's basically that shape because he didn't want to lean on and cause damage to the air con hoses. He's found from other cars this doesn't cause a big issue. He's forwarding me through photos shortly, but the even the jig looks cool.
Only downside I can see so far is my intake temps seem to be higher. Not sure how much of this is because of the ambient being so high, but by the time I've sealed the pod in a heat shielded box we should be all good. Note I did change to a larger R2C pod at the same time, so I don't think this is the fault of the intake pipe.
Andrew also modded the fan shroud while I was there, so I've now got everything I need to overhaul the cooling system except the fan controller for the thermos.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
