I'm rebuilding a VQ25det at the moment, it seems Nissan cant sell me any big end rod bearings... Wat?
I wonder if VQ35 ones will fit, anyone know a way to find out? I guess I will have to measure the stock rods and compare them somehow...
I didn't do anything....
But Scotty saved me by sourcing and fitting a new rad this afternoon, after mine decided it no longer wanted to keep the water on the inside... Bleeding the cooling system is a biatch...
Good to finally meet Aaron as well after all these years..
Thanks again mate!!! :cheers:
the bearing grades will be very minor differences in clearance...probably 1/10th of 20thou. If you are not buying nissan they will only have one grade. If you are buying nissan you could carefully measure everything....or just pick the middle grade and go with that
How did it go on the way home Nick? I should have sold you that spare coolant mod, it would have been quicker to fit that than bleed your engine...
Ran like a dream thanks Scott. Temp gauge sat where it is supposed to the whole way home. Also drove across all possible bumps to give it all a good shake for bubble movements..
Swapped out the battery, and as expected the little window was showing bright red... New battery has restored normal starting..
Ha good to finally meet you too mate! Glad Scott got it all sorted!
Just fitted the HKS sensors for the F-con. Nissan was nice enough to leave me a decent spot to drill and tap the IAT sensor into the pipe the BOV mounts to, and two holes blanked off that I can mount the MAP sensor to. Just need to plumb the MAP sensor in now, thinking directly to the plenum rather than try and tap another thing in where the factory sensors are.
Also dropped the oil, replaced with fresh 300V and a Greddy filter. Guess I've got one more fill with 300V, 1L left over :/
Best measure of intake pressure is in the end of the plenum. Same place Nissan put the barb for the OEM sensor.
Right I'm with you now, the tiny hose on the end. Although there's also a factory sensor in the BOV pipe too.
Went on a little cruise with the v35/36 club of WA.. theyve adopted m35's into the club as theres not many in the scene. Met my first m35 other than mine today as NickM91 came along for the cruise .. had a great time and shared lots of info.. :cheers:
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
