I replaced my castor bushings with superpro ones. When getting an alignment done, the castor was slightly different between the wheels but it hasn't proven to be a big deal. However if I were to replace the bushes again I would have just bought adjustable arms.
That must make it Adelaide cruise time! There are a few people keen for a Feb cruise.
I did really exciting things to my car: I retuned the throttle. *YAWN* Feels better though.
Omg a m35 has new wheels def time for a adelaide cruise lmao
Nah they look good dunc cant wait to see them on .
But all jokes aside def time for a adelaide cruise
Considering he's had the car off the road for months and missed a years worth of cruises, I think it's warranted.
Lol i love stirring 35 boys up always get a bite, hey my car was off the road for 9 mths came back on with engine transplant 19" wheels an 340kw. So hell yeah lets cruise lol its warranted lol.
This :) (yes my car needs a clean, and yes its black, Haven't looked for a matching grey paint yet).
I run one of these on my head unit.
Micro SD to USB adaptor.
So neat and out of the way. Less likely to knock it and bust your usb input port. It barely sticks out lol.
Neat job you did on the gauge intstall and surround.
I received a red and yellow box today with the same two letters repeated. Wating on another box to arrive with HKB on it.
Thanks guys :)
Yeah made it up, was quite a bit of work.
Just a few pics from the weekends work;
@Jezboosted Thats handy :) I'm going to a difference system all together so no more of this front usb crap I can't stand it getting it the way of my cup holders when i throw a maccas cup in there haha.
Edited by WgnZilla
Spent 3 hours with a red sharpie permanent marker fixing the sun-bleached red stitching because my car has spent soooooo much time sitting in the sun at my mech having work done. That, and the fact that I only have a carport available until my under-house 4 car spots are ready...
On a brighter not, my internals arrived on Monday and went straight to the machine shop, where my block is waiting: hopefully I'll be looking at an almost complete engine in the next week, then it's being on the run-in week of driving pleasure!!
Destroyed a new $1600 clutch at willowbank last night! Whatever holds the throw out bearing in the pressure plate (pull type clutch) decided to fail
So started the process of pulling out the box, had to cut the front drive shaft bolts with a grinder because a un named favorite business on here who fitted the clutch rounded the nuts off.
Edited by GTR260
took out the gauge cluster out of the m35 (volts boost torque) removed the boost and installed a 30psi autometer one in its place. works a treat and for the first time since scotty did all the mods i know how much boost its running hahah
get a hdi EBC with digital gauge.
Craig had nothing but problems with his HDI and I am now of the opinion a good mechanical option is best. He already has my HD actuator fitted, and the manual bleeder is a solid performer. No need for the defectable electronic options imo, even though they allow slightly better response. (due to the little spike they give.)
Although, some EBC's have an overboost warning, this is more important than a boost gauge I feel.
+1
No difference in performance between the hdi and turbosmart T.....Ive been swapping between tge 2 for weeks.
The only really difference is the hdi spikes like a mofo and the T maintains control.
