309kw @ 19psi dropping to 17 (i think :P)for my 2nd run in tune on the heartbreaker dyno. Running it rich until full boost tune at 3000kms... 800 to go :D Full boost will hopefully be around 25psi with the 3076r and Tomei built motor, I guess we'll see where she starts to choke.
Redline is now 8000rpm with the new harmonic balancer, which is entertaining lol. The Old Girl actually feels quick, now to get her fast...
E85 then
That is exactly the same as mine 19 dropping to 17psi made 338 on morpower dyno so if you took off the drop for the heartbrake dyno would be about the same ! Well done what rear did you end up running same as mine ?? Got a dyno sheet wold love to over lay it be interesting , yet again well done:)
Was going to keep playing with stag but the new drag car is taken over.
Ill just retune more boost 21-22psi and turn the water on should do for now .
So coming out on the cruise soon
Cheers jase
Heh, I don't have access to the dyno sheet at the moment, I'm away on work. I have this crappy screen capture from a video of the run taken on my phone.
I'd love to post the video but it'd be way large, suggestions on how to post it may help me though, I have become less computer literate as time goes on.
Still running auto rear, I have been babying it on launches until a couple of further upgrades are made, just bought an apartment so spending on the stag is halting for a few months until I get money back in the bank :)
It will be interesting to see how ours compare on higher boost, I am really looking forward to turning the wick up and putting all that Japanese forged to the test :D
Yeah you got a fair few $$$ worth of name brand parts in that engine :) should be able to handle a gut load of boost but I reckon your turbs as mine will will nose over soon after 22ish! Launches will be fine just not on preped track ,have you got an lsd in? What clutch you end up running,
Any way crappy pic and excuse filthy car but fitted my s1 miester R full carbon bonnett yesterday (über rare) very happy :)post-76904-0-59454000-1392384663_thumb.jpg
Bonnet looks great!
Yeah, will just have to wait and see where the turbo finishes up, but I built the engine with the future in mind, so I can upgrade the turbo if I ever want more power. At this stage I'd be pretty happy with 330wkw on the heartbreaker tbh. Anthony @ Jaustech seems to think that its easily acheivable, he said the engine has so much left in it, which is reassuring :).
No LSD, I'll get a manual rear cradle in time, as finances allow. The next upgrade will be DBA4000 33 GTR front discs and matching 33 GTS-T rear discs and ProjectMu Club Racers Pads. I only have a few thousands kms left on my current brakes, so it will be a necessity more than a want.
I have a near new 2nd hand twin plate Nismo GMAX II (that I will sell one day when I get around to it lol) but i decided i wanted a new coppermix instead, so in the meantime I am running an extreme single plate something or rather... heavy as f**k, but holds the power :)
Edited by stageaharts
you two have insane stags!
i installed my cusco coilovers and adjustable arms in the front
sitting pretty now, might roll the backs and drop it a tad more, but dont want to go stupid low.
Nice one harts :)
Engine build specs?
Damn I'd love to go nistune board 6 and bigger injectors :(
After tune I'm putting it up on gumtree for sale I think.... All in my head, but if I got defected I'm rooted & would have to part it out. Never had an issue, moreso 'whatif' factor.
Will post back after tune with the result. I'd be happy with any result higher than previous tune pre engine rebuild (was 255rwkw at 1bar).
4b, looks awesome mate !!
Thanks tangles, as far as the engine stuff is concerned it's a bit of a list so forgive me:
Stagea Rb25det overbore to 2664cc, 8000rpm redline, running on e85.
Garret 3076r
Tial 44mm external wastegate
AM Performance low mount exhaust manifold
Tomei forged Pistons
Tomei forged Rods
Tomei Oil Pump
Tomei Sump Baffle
Jun Crank Collar
N1 Water Pump
ACL Race series bearings
ARP Main and Head studs
Ross Harmonic Balancer
Tomei 256 Poncams
Supertech valve springs with titanium retainers
Full head recondition with mild porting and oil control mods
Shaved Deck
Splitfire coilpacks
Injector Dynamics ID1000cc injectors
Low profile fuel rail with external Turbosmart adjustable fuel regulator
Walbro e85 fuel pump
Apexi pod filter
AM Performance intake and intercooler pipes
Cooling Pro return flow intercooler
R34 GTT Nistuned ecu
Z32 Airflow meter
Blitz dual solenoid SBC iD III boost controller
AM Performance split dump pipe
Venom 5" high flow metal cat
Blitz Nur Spec cat back exhaust
R32 GTR pull type manual gearbox
Extreme ceramic cushion button clutch
Setrab 19 row oil cooler
GReddy catch can
Speedflow fittings and braided hoses
There might be more, but I forget on purpose to ease the financial pain :P
Painted black for the sake of stealth :)
Bloody hell stagharts that thing is gold dipped ;) you could have bought two units:) should last for a 100 years ! Mines lasted a year of fun with full stock internals making what I do . You should chuck a bigger turbo on it and while your at it build a gearbox and push the mofo.....!
The box seems to be the next weakest link in my set up just waiting for it !!!
You have full tune done for the drags in end of march? Should run it :)
Haha, I have learnt that nothing is bulletproof in the world of modifying :P But yes, I built it with the future in mind. In the longterm I'm sure I will put a bigger turbo on, bit I'm in no rush :)
I know what you mean about the box, mine seems to handle it fine at the moment, but I know that 300+ wkw is right on the edge of its working range.
I think that the tune should be done in March, bit the limiting factor will be whether or not I am in the state at the time.
Your car looks very similar to mine now BTW, black/carbon bonnet and black/carbon ganadors :) lucky I have black wheels hehe
Mine isn't, just professionally painted satin black (2008, didn't even know about wrap back then)... was worried about the chances of getting pulled over being increased if it was carbon... but I do love the final motion carbon bonnet for the s1 :)
went through a bretho last night, gave me a chuckle.
large rbt setup:
blew into the box
0.0
car infront took ages and the cop started putting his hands under the gurards and coudlnt fit
"mate i think this is too low, have you changed the suspension?"
"yes"
"hmmm, " calls another cop over "hey do you think this is too low?"
cop2- "yeah probably" walks off
"hmmm sarge will know....hey sarege, is this too low?"
Sarge "For f**k sake mate were busy, seriously!"
"ok mate off you go"
lol
  • Like 2
oh, so lucky!!! Thats what stresses me out
0.o
Being f/time student with no cash, I couldnt afford to do Regency if ever defected.
Pretty certain Im going to advertise properly - Gumtree - once dynotune done next week.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
