Took the tractor for its first visit to the Dyno. I think it did alright with its stock turbo and 3 inch turbo back exhaust :D
">http://7I7CgA0.jpg
Not to shabby, what ecu are you using to tune it?
Good stuff.
So what's next?
Hopefully injectors and new turbo but will have to see how the funds go lol. I also have the classic faulty pressure switch causing the 4wd to come up so will have to deal with that at some stage too
mounted the fcon in the other little glove box thing
">http://yGhQlVt.jpg
  • Like 2
I have the same issue with the pressure switch, such a pain, I wish there was a reasonably priced fix for this
  • Like 1
Car got tuned today with an adaptronic, drives awesome now. The ss1 turbo ran out of puff unfortunately, so thats all we could get from it.
Looks good to me mate.
It may have run out of puff for chasing a higher number, but it would be my choice over a bigger (laggier) turbo any day. Probably faster everywhere bar a drag strip too :), at least where I live - hardly a straight road other than the freeway around here.
  • Like 3
Lucky I'm not in sa then and yes I did leave the windows down
No worries man. I could be wrong anyway
Just for some reason thought I would check it out there .
Obviously it's not that hot this time of year!
Written off due to to expensive to repair
same thing happened to me 2 weeks ago, got payed out friday.
Wife lost it in the hills, hit a oncoming car and went down a embankement through a fence, everyone was ok
thats my stagea ownership over, just going to buy a normal family daily this time...
cheers
darren
Edited by jet_r31
Fitted some tan leather 350z seat into my m35 today bolted up perfectly. Passenger side is a bit to low but will fit some spacers tomorrow. All the electrics and airbags are plug n play aswell :-D
  • Like 1
Now that is good to know.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
