Fueled up after a full tank of my normal driving with putting the foot down a couple of times to ahem... Blow the cobwebs out. 50/50 open road and city driving.
350RX 616.5km 67.3L which by my maths is 9.16km/L and pretty much about same as what I was getting from the 250RS. :)
Replaced all the door speakers - I thought they were original factories all round but no, only in the front. The rears had an amazing $11 pair that took the quality of the sound right out of the 50's and into 1960's spec! :P
6.5 inch all round, used the original plastic mounts, cutters and a power drill to get the fronts sitting nicely :D
Today I have made a double din surround facia for my sony dvd player. I made it from balsa wood and will be fibreglassing it tomorrow then painting it black to tie in with my unit.
I have also installed a cigerette socket into the rear wall compartment for when I travel with my engal fridge. post-77821-0-23273700-1419751418_thumb.jpg
In the last few weeks my Stagea has been detailed within an inch of it's life by a good mate, and as is the fashion in recent times killed a rear wheel bearing an destroyed the stub axle.
Managed to accumulate all the necessary parts juuuust in time to get it all together for the Christmas break.
Other than that, she's just been belting along happily about the place filled with kids, bikes, presents, drunk mates, and my bloody mother...
  • Like 1
Damn mothers ruining all the fun
  • Like 1
Swapped out my o2 sensor. After spending an hour attempting to mangle the old one out, I finally found the perfect socket designed for it. This + short extender + half inch rachet and half a second of effort to loosen it up to unscrew out.
12 bucks too, thanks Beeps Auto Parts!
Now to see if the new one makes a difference..
  • Like 1
Finished installing cruise control kit from Commsman, all good! Used an Axxess SWC interface with the factory switches and my Alpine head unit, works perfectly.
Put on my brand new, second hand front quarter panel to fix my roo damage. Love Yahoo Japan, $21 with indicator! (plus freight of course). Just had to swap the grey trim piece. No $550 excess, claim against my name, car gone for a week or newly painted panel next to 10 year old paint.
Found this rubber drain under the battery compartment when I removed the quarter which was clogged with dirt and leaves and bugs and ewoks, remember reading somewhere about this compartment filling up with water and corroded third fuse boxes. Might pay to clean out the other side as well.
post-135423-0-36941900-1420069284_thumb.jpgpost-135423-0-97599100-1420069306_thumb.jpg
Next project:
Going to take off the front bumper to see what size cooler I can fit (think I'll go for a PWR)
  • Like 2
Started changing the oil last night with the car on the ground, naturally I fumbled the sump plug and lost sight of it. Ragequit and went back to it this morning. Cue 10 minutes of fumbling round in the drain pan, first with a random piece of bark, then with my fingers, all to no avail. Eventually found it trapped in the top side of the undertray. Sigh.
It's still not really burning any oil though, I'm getting out almost as much as I'm putting in despite the enthusiastic driving it gets every now and then.
Drilled new holes to lift the number plate up a bit to cover the raised area on the bumper and then cut out the lower grill which was cracked and faded and replaced it with black mesh. It's only the stock bumper (and it needs a good cut and polish) but I think it looks a bit neater.
post-135423-0-03085500-1420945413_thumb.jpgpost-135423-0-98814400-1420945440_thumb.jpg
It's wet here also.
Not to the Stagea but from a Stagea.
Slipped a Neo into the R32. Cant wait for the grunt.
High mount and FFP etc.
Edited by 66yostagea
  • Like 1
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
