Just picked up the M35 and first impressions...
Seating height is much better imo which was the main inspiration for the seat swap. I'll get a few pics once the sun comes out.
The aero front bar is also awesome however one of the driving lights needs a new globe :(
Pics please!
Managed to clear my defect today (wheels too wide [cops around here aren't so great]) by painting and fitting these R33 stockies. They look stupid but at least it's cleared.
Also installed new bonnet struts so I can FINALLY work under the bonnet without the risk of skull damage haha.
  • Like 1
Never before in the field of human endeavour has so little been achieved in so much time by just one man.
Today I replaced a 3 inch length of 5/16" hose on my turbo watercooling return line.
It took four farken hours go to woah; I feel like a retard.
I noticed a significant drop in the rad recovery bottle a few days ago, and when I went looking; I found coolant all over the passengers side steering rack boot. Turbo is directly above this area; great!
Looked around, no real signs of failed hoses but coolant stains on the hard line, hmmm...
After removing the hose, it looks like the hose is delaminated internally due to the radiant heat of the exh manifold, and forcing coolant up the reinforcing braiding and out the cut ends of the hose.
Then did a cooling system flush and new coolant.
As per protocol; thanks go to Scotty for the cooling system mod, which make bleeding the cooling system a breeze.
Good job Scotty. ;)
  • Like 3
ok photo time now that it's finally stopped raining near the beach :P
Everyone has seen an aero front bar before so i only took 1 quick photo.
The others are just random pics of the GTR seats.
The car is pretty messy atm but due to the weather i haven't had the chance to give it a decent clean...
  • Like 2
Dude they look so good. What's the comfort level like?
If I had the black interior I would definitely be putting this high on the mod list.
It's taken a bit to get use to comfort wise and i am finding myself fiddling a bit with the seat position but i'll get it right. The biggest improvement is the height... so much better as now the rear view mirror doesnt obstruct you view at all through the front window.
  • Like 1
I didn't but i did take notice when i was carrying them and to be honest i would say the weight was very similar.
The drivers M35 seat may have been ever so slightly heavier but that may have been due to the air bag solenoid + locking set up... I could barely tell the difference.
Noice! Excuse my ignorance but what are the two switches in front of the cup holder. My RX only has the one switch on the console for the attesa.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
