My M35 on the hoist....
Slowly working through the problems of adding 6sp RWD box from a 350z :P
(which means i'll have a transgo fitted auto box for sale shortly)
Edited by Beregron
  • Like 3
I wired up my aircon fan so that it blows instead of sucks. Amazing what correct airflow does on a warm day...
Also sorted my AWD issue; many thanks to Scotty for his help in sending me bits I thought I needed, but didn't.
Not my best week with electrical work this week...
  • Like 2
Love me some hoverstag action. :wub:
Dale what was the issue with the AWD in the end ?
aircon fan was originally behind condenser?
It's great seeing progress.
Still issues to overcome and i'm hoping as everything comes together others might have some progress on their tuning endeavours
  • Like 1
My stupidity apparently. :spank:
I had Scotty send me an Attessa main relay, as I believed everything else was ok.
After fitting it with no change; I then moved down the line to check for continuity at the fusible link, and discovered this;
12064414_10153697918882392_1014231804_n.
FYI; the centre pins are the 30A fusible link for the Attessa ETS. The 50A is the BCM fusible link.
I'd checked this link before visually and was sure that it was ok; but I think the burned piece of the link must've just been sitting inside the connector; looking sneaky.
When I popped the lid off to poke the multimeter probes in; my stupidity was revealed...
​Found the part on EPCdata, was quoted $35 each from Nissan Aust, so I'm going to grab a few online for $11ish (free delivery).
Poked in new fusible link; no AWD light and pumpy noises. Happy days.
Damn; I should've been a hand model...
  • Like 1
Nah, I fitted an HDi intercooler kit for my tune a month or so ago, and fitted a thinner fan to suit; was SURE I had it going the right way.
In traffic once the weather warmed up; the car seemed to be running hotter than I remember. Once moving; the temp would drop into the low 80's, high 70's; like normal.
Sure enough; it was throwing hot air out through the grille; so I just had to pop the pins out of my connector, and switched them around; back to normal.
Like I said; not a good week for me with electrical stuffz...
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
