C34 is 14mm. Not sure about M35. But you really you have at least a set of spanners if you own a car
Thanks for the info!
Yeah I really do need to get a set, haven't really needed any since I moved to Japan
went ahead and ordered a set from KTC
https://translate.google.com/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.kpt.co.jp%2Fdetail_1.aspx%3FGId%3D14188%26MId%3D161%26FId%3D4%26SId%3D19%26TId%3D68%26FthId%3D194&edit-text=
installed bonnet damper kit today. it is for 350z but could be fitted on m35.
need to drill a hole on each side of fender due to m35 doesn't has it as stock (350z should have the hole as stock)
need 2 medium length bolts and nuts also.
open to stock height
happy with $60 delivery :rolleyes::rolleyes:
Looks like a handly little mod, interesting silicone hose layouts/ colour choice there mate!
that's BOV return hose. my bad i make wrong length when buy it... i re-ordered the customized one for 75cm long to make it beauty.
the hose is reinforced silicone hose, good for intercooler
Edited by YangLIU
Put some fresh front pads in yesterday, and chucked in some new plugs in at the same time.
Spent the first half of today chasing down vacuum leaks -.-
Still running like shit. Feel like I've done something daft somewhere/split something without realizing
Spent the last couple of weekends prototyping a rail delete kit. Covers bolt in place of the rails and have (printed) gaskets to keep the water out.
The covers don't look as good as a full patch job and respray obviously, but I like the fact that its reversible if I ever need to put the rails back on.
Cheers
  • Like 4
Link? Did you get my PM?
Cheers
That's a good job!
Hunting down a intermittent engine light issue. I have narrowed it down to something in the dash or the actual dash. Iv pulled everything out and cleaned jiggled wires. Just a question for those in the know, what is the black box with all the wires that is on the right hand side of the dash hole?
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
