Scotty says he has a tiny bit of rubbing on full lock.
Plus had to roll the rear guards.
19 x 10 + 30 all round
You might need the Axis ride height for 20's
Edited by conan7772
Yeah i read that somewhere. Do you know what size spacers.
As the others have said, 15 or 20mm.
I run 10mm on my Nismos which are 19x9.5 +40 and have no rubbing.
I don't think I could get away with 5mm spacers, nor would I try for that matter as there is not much room in there.
So I finally get around to doing a few things today.
Replacing a burnt out globe in the cluster, its only the shifter position but it pisses me off at night.
Replacing the weeping radiator. Just ordered one from Natrad $260 inc!!! Bursons wanted $465 (for the same thing). Pickup at 1pm and then the fun begins.
Edited by malialipali
  • Like 1
fan clutch has a little bit free spin, but there is no overheat problem atm. i know most people would say don't change it if no overheat problem, but i want to keep engine more cool!
so ordered new fan clutch (Shimahide branded from JP). now i could feel very noticeable strong wind under bonnet
for someone who has overheat problem, try to change the fan clutch. even though you test the stock worn viscous fan in cold and it is tight enough with just little bit free spin angle. it may have huge difference if you change new fan clutch.
made in JP
good quality
no need to take out the fan shroud, just lose 4 bolts on fan pulley and make some angles to take viscous fan out.
thinner than stock one
new pads arrived, ready for daily fun.
Edited by YangLIU
made in JP
Hook a brother up with the fan clutch ..... link?
Cheers
woohoo , got it all done.
The cluster globe was not burnt out , someone had been in that cluster before :glare: , the track on the PCB was worn away / cracked in one spot, soldered that and tested on bench all working.
Biggest issue was re-calibrating the needles as I had to strip the PCB out.
Radiator was a bit of a pain, but all done, the old top tank started to come apart in my hands, I'm genuinely surprised it had not gone bang.
One more burp tomorrow morning and a bay wash, hope nothing else breaks for a few months, I need to get started on the mods.
Got the Stag back on the road today. Hit a skippy on Easter Monday. It's sat in a forlorn state since. Picked up a complete roller and today it donated its face. Need to massage out the rad support behind the left hand headlight, but it's passable for now.
  • Like 1
May was a big month for the ARX – finally had the head unit replaced with a single din Pioneer and Kanatechs fascia. For the benefit of Canberra Stagea owners, BDL did the install. Then a gearbox flush and off to Scotty’s Customs for a dump pipe, front pipe, cooling mod, new plugs, rocker cover gasket replacement and attessa, transfer case and diffs fluid change. Well worth the trip.
Got the following completed today ready for wheels tomorrow
- changed oil and filter
- replaced front inner passenger guard (grill due to transmission cooler in fro t of it to let heat excape)
- cleaned engine bay
- put the lower stone guards back under the front of the car
- finished securing Axis kit
- painted R34gtt front calipers black (yet to do silver 'NISSAN' writing
- placed spacer on exhaust so it clears kit70fba96b223414a91bfb5704af408dfb.jpge7176bddd3f9a300371b941f1c27eded.jpgdfb4aa956456a135d743585ef51abea3.jpg96f12d9fe38c063b4231f25877508790.jpg2a6161fa8529800f6a2d8ed588807374.jpg
  • Like 2
yeah, my kakimoto also fight with rear bumper. exhaust shop just heat the rear muffler pipe then make a bit angle to avoid the bumper.
Edited by YangLIU
Mine is sold about to go to its new owner so wont be touching it.
Ok so front brakes come up a treat
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
