So I haven’t posted in a while here but I picked up a Takeros kit which needed a bit of work and paint and it’s slowly making its way to being done.
its had the fibreglassing work done thanks to one of the awesome dudes at my work, I just need to bog it from the front and sand everything down and prep for paint.
I will need to remove my tow bar which is a bummer but not the end of the world.
6EC7C5B3-3233-4E7D-845E-ADCF417EB0C8.thumb.jpeg.443f5178a0f80fcb8cbc7fa688b22c08.jpeg1F85272A-6902-40FC-BDED-865C0CA93C38.thumb.jpeg.5394924fdf418fc931922f904520368d.jpeg
  • Like 1
Hi all, haven't posted in awhile, wagon been good, have horn/clockspring issue to fix tho... just saying hi. See lot of Stageas around Hawkes Bay now....
was doing the long distance relationship thing for awhile so car had good workout over Taupo rd.... some night shots... Cheers
  • Like 2
  • 3 weeks later...
Finally got around to kind of fitting up my rear wheels for now (Garson Ryugi Deep Racing 18"x12.5" -22). Adjusted suspension height and damper and smashed guards out with a guard roller, phone books and a jack handle until I either order bolt-on flares or bite the bullet and begin a widebody...
  • Like 2
  • 1 month later...
New wheels and tyres ?
BBS Lm replica 8,5x19 et45 and 25mm Bolt spacers
235/40R19
Weekend work. change rear upper control arm and next week wheel aligment then I can get better pictures
Edited by TukeH
Tyre size forgotten
  • Like 1
  • 3 weeks later...
Just sold the black PNM35, so we're back to a one-Stagea, one-Leaf family. :( It drove better than the silver one (had no options so was lighter, had hard bushes, lowered, better brakes and may have been shift-kitted) but since it didn't have a towbar or centre-rear 3-point seatbelt it was voted off the Island.
It served me well though, I bought it because I was doing a 600km round trip every week for work last year, and the mileage allowance I was paid meant it was basically free, so anything I got when I sold it was a bonus. Now I just have to convince my wife we should use the proceed to fit new bushes, suspension, brakes and a shift kit to the silver car. :P
  • Like 2
  • 3 weeks later...
Evo 8 seats finally in. Stripped almost every bolt getting the old rails off and had to drill 2 of them out and re-tap (shhh don't tell).
Sits much lower than stock, and wouldn't recommend if you're a big person. They are quite snug on my ass.
Now to figure out the seat airbag delete...
  • Like 4
You want to solder a 2.2 ohm resistor into the wiring behind the plug  on the harness; that's the value of a seat airbag.
Poking it into the ins of the plug won't work, needs to be soldered into the wiring.
Seats look great in there.
Cheers, I've figured that bit out.
Totally voiding any insurance that I'm paying for and my safety probably too, but hey they look good right?!
Installed roof racks and roof basket, 3" turbo back straight pipe to a single 3" blast pipe and took the nugget to Powercruise for the weekend. Scrubbed up alright...
  • Like 1
  • 3 weeks later...
Finaly had time to take dp Off.
I have to make new flange because I bought
Wrong ☹️
Just 2hours to remove dp and make flange and I did not lower the trans
 Without the induction heater one bolt would not have left off
  • Like 1
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
