hahah yeah ill want that too
with my new gearbox
well for $500.00 for the best shift kit i can get in mine. im happy.
that way if the box eventually gives up, i send it to him he rebuilds/upgrades the box for $2000....im happy with that
especially if Cihan's got something in mind for Trans ECU mapping like ironpaw said..
yeh. although my plugs in the car were pretty new, they were changed on complianced which im told is rare..
Damn. My compliance shop didn't even change the bloody oil. :rant: Stuff that came out was fairly black goddamit.
Lucky for me I changed it /trans oil/oil filter/plugs/air filter/and drained the rad water, and filled it up with the real stuff..... :rolleyes:
lol they changed oil belts plugs power steering brake fluid.. pretty much everything except the transmission oil.
Im kinda glad they didnt change the trans because if they put the wrong oil in i may well be f**ked!
Edited by AaronNM35
neither did mine!!
removed all the good stuff though
i spoke to them prior to compliance and said i'd much rather a way you get around keeping all the goodies..
especially the remote start..
why cant they get rid of HICAS on compliance lol
Just some quick notes on the fitment of the 'power duct' to my NM35.
1. It makes more of a turbo induction noise on boost which I like. Keeps everyone guessing
2. Following a truck with hay bales on the drive over to S.A. means your air filter gets straw in it
3. Easier to see how dirty the filter is!
4. Economy I would hazard a guess is slightly better. I'm getting 550 to a tank of around 60-65L driving in peak hour.
Also, the Tanabe's coil overs are going well. Still wallowing a little (shock damper rate is lower than the springs require I would assume). Corners like it's on rails! Quite neutral with some understeer with light throttle.
Anyone know if the Autech Axis model has aftermarket sway bars? Me thinks so.
i stole mine off my sisters v35. good thing i did too.. she wrote the bugger off!
Ok, better say what I have done somewhat lately - Tiptronic was reversed, to stop me changing down gears...
GB sway bars I put on last weekend, and Lowered Eibach springs went on earlier this week- waitin on 19" Rims, lowered ,the 17 " stockies look.... ridiculous! Car handles Amazingly for simple upgrades, much more faith in it.
R32 GTR brakes are waiting for the new wheels to come along, so I can stop properly :thumbsup:
Picked up a Z33 midpipe today from Northshore Prestige (thanks Guys). Thats an upgrade to the massive/quiet centre muff that on there. Apparently just got to get it extended 6 inches...
Awesome to see some upgrades for the PM Alex!
Anyone know what the Tein Super Wagon's are like? Harsh as f**k?
There's a bit of anti Tein sentiments here ain't there? :teehee:
No, not at all.
From all accounts they are a very, very good kit but when there are other excellent kits floating around and cost considerably less, well I guess that's why most of us don't have them.
I still would like to buy a set of Teins. The price was crazy last time I looked though.>_<
Also:
Are you guys talking about crap brakes on the stag because you:
1. Have crap pads?
2. Do heaps of braking/accel during 'spirited' driving, and the brakes can't dissipate the heat soak so you get fade (could be fluid related though)?
3. Just want bling?
I would really like to know!
I've done a few bedding in stops to bed the pads properly into my machined rotors (stupid compliance workshop....), and it pulls up a treat now. ABS works too! :thumbsup:
I've also changed the fluid from DOT3 over to my ELF semi-racing fluid that I use in the Datto.
Also:
1. Have crap pads?
3. Just want bling?
Im going to go the route of new rotors & pads shortly, but stock calipers. Will see how it goes, I wont be 'tracking' my car so I dont think I reallllly need big f'off brakes.
Would be interesting to see a comparison between R33 / Brembo / Stock in pull up distances from 60km/h. Doubt it'll happen though.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
