Two most recent additions after exercising quite a bit of patience...
New trans cooler
Cooler is a replacement RX7 oil cooler.
Thermostat is made by Hayden and allows for a flooded system, so no pressure loss when the thermostat opens.
New wheels
Been waiting to complete the set of these for a while.
They are a full set of the fronts from the 370z Nismo edition. 19 x 9.5 +40 with 10mm spacers to ensure no rubbing
3ab38b0a-3a51-47d3-b4ee-f3e9f2d0d68a_zps
4435963d-3678-4942-b7b9-785e57b93d1f_zps
  • Like 1
very nice look! viewing your pics i've first time wondered- S2 M35 has another rear bumper than S1 does! have anyone fitted S2 AR-X rear bumper to S1? it seems to me it should sit in properly
The S2 has the same mounts as the S1 for the rear bumper Erop, but aren't they the same item?
My rear bumper is off the RX so it won't look great due to the flares on the ARX.
The Axis rear bumper should fit up on an ARX pretty nicely.
Edited by iamhe77
Whoever designed the location for the dipstick hole on the PNM35 should be shot. Had to use the light on my phone to find the damn thing after checking the oil in fading light tonight. :angry: I'm always paranoid I haven't put it back in properly too.
Yup, agree, but you do get used to it.
Bets thing you can do is actually spray some cleaner down there, with the dip stick in, and clean off the little triangle guide. That way it's a little easier to see, but also your not sweeping shit into the engine when you do put it in.
New trans cooler
New wheels
Cooler is bloody huge Cam, why such a large one?
I guess it will definitely do the job.
Wheels look epic, 19x9.5 +30 has got to be the perfect width/offset for a wheel on these; they suit it perfectly. :thumbsup:
Changed back to nsw rego today. Cant say I was all that thrilled about it. To renew WA plates was 580 for 12mths, thats rego ctp the lot. It was easily over double that over here. Any one know why?
Also interestingly my WA rego said the car weighs 1415kg and I had it weighed... blue slip says 1680kg. classing it as an extra large car so you can see where the extra cost came from. what figure is correct?
Massive thanks to Alex for today :D.
Nismo thermostat, Fenix radiator and Scotty's coolant mod fitted.
I was extremely surprised with the radiator, the core size stated by fenix is 42mm and it was a direct fit no modifications needed at all... Oh sorry except had to cut the top hose a bit because thicker radiator is thick.
This was probably
Get yo hand outta my valley!!
Coolant bypass with extra flooded valley.
Lowest temp seen was 77 degrees with the AC on, highest was 98 when idle then thermos kicked in and smashed it down around 90 without a problem.
http://www.ebay.com.au/itm/Nissan-V35-Skyline-Heavy-Duty-Alloy-Fenix-Radiator-/181216475316?pt=AU_Car_Parts_Accessories&hash=item2a3157f8b4&_uhb=1
Fenix Part Number: RACE1631-FA42A.
Edited by M35woah
  • Like 1
they are different, shurely
S2 one
S1
so i do like S2 much more) will look for S2 AR-X one)
i don't want to put AXIS one
So bloody large because I am bypassing the radiator... plus it fit perfectly under the reo leaving a heap of room behind for future mods (although the thermostat did take up a little more than I expected).
Wheels I have been slowly collecting over the past 2 years and would grab one or two when they came up on Yahoo for a reasonable price.
The pics don't do the wheels justice and make them look dull and lifeless due to the shade.
Yes, those two are different but what I am saying is that the S2 ARX has the same rear bumer as the S1 ARX as you can see in the link below
http://www.goo-net-exchange.com/usedcars/NISSAN/STAGEA/700123019430131225002/index.html
S1 Axis and S2 Axis also share the same rear bumper.
I guess you could put a S2 RX or Axis S rear bumper on and have extra bulges added so that it matches up with the flares on your ARX.
  • Like 1
Great to hear, the Mishimoto radiators are a pain to fit. So the thermos went back on fine?
Good price too.
kinda, it sits OK, probably could have trimmed some minor areas of it, but the temps I was getting and how quickly it dropped during idle I don't think I'd ever worry about it.
Top corner of the shroud where a bolt goes through has broken off anyways, but arex HKS fixed it easy.
Edited by M35woah
Got a screw in my rear right. f**ked around putting pressure in it just to get to work until i could get into a local tyre shop near work.
Paid $100 to get 4 new tyres I supplied fitted to my 19" wheels on the Stag and balanced. :D
LOL! Read that completely wrong. I thought you paid $100 for a set of tyres!! I thought "Do you even grip?".
I got a screw in one once, drove on it for a while just tightened it when it was leaking lots lol.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
