So on Sunday i installed my TEIN's which i bought back in April on an impulse buy even though i didn't own a Stagea. I was adamant i was going to buy one and i couldn't complain with the price.
I wasn't sure how to go about installing them but as i took the wheels off i saw how easy the install was. Took me 3 hours which included me changing the oil.
So far i'm very impressed with them and it is sitting 50 mm lower at the front and 25 mm lower in the back. It is very low and i will raise them up a bit and drive on them for about a month and then i will re set the height
Looks the goods; any reason you didn't like the BC's?
Are you planning to upgrade and use the EDFC on them?
Nothing against the BC's, they were good while i had them on and i have no faults with them.
Just like i said i already had the TEIN's before i got the car, so i was going to swap over whatever came with the car i bought regardless what came with it. Another reason so i knew that the suspension is new and is what i wanted.
Don't think i will go EDFC but who knows in the future. I nearly have the car to the state at whcih i wanted it, i just need to do the exhaust now which is on its way from Japan
  • Like 1
Hi Luis
Nice car. Few questions
- did you feel that your car was faster (0-100kmh for example) from the HDi intercooler
- with the boost controller, pardon my lack of technical intelligence here, I thought it makes no difference given boost is ultimately controlled by the ECU?
Thanks
What are you doing with the BCs you took off? Are they in good condition? Would you be interested in selling them?
Hi Luis
Thanks
In all honesty i haven't noticed a major difference, I did change the boost controller at the same time which would effect me noticing the difference in intercoolers.
In regards to the boost controller, the factory boost was 1 Bar/14 psi (going off the factory boost gauge) and with the new controller when i have it all set to default the turbo is producing 8 psi. Then with a bit of tuning i have got my low boost set to 10 psi and my high boost set to 16 psi. When tuning i did hit a boost spike of 19 psi but am not willing to run that with stock injectors.
With the ecu in the VQ25DET there is a factory boost controller which i have replaced with the GReddy one. The wastegate is now being controlled by the GReddy unit not the factory computer. I am now able to control peak boost, the boost curve and how quick it takes to get to peak boost. The GReddy is a great little unit and very easy to use once you understand how to use it.
They are in great condition, so I'm selling them. I advertised them on the Victorian Stagea Division Facebook page and already have a buyer. If he doesn't buy them then ill put them on gumtree or somthing
Edited by DrLui
If they don't sell I interested price dependant
After replacing my roo damaged front quarter I also imported a complete door (the old one had kangaroo tail bone dints all along it)
So out with the old post-135423-0-73879700-1441188112_thumb.jpg and in with the new using my one man door installer thingamabob post-135423-0-04032600-1441188165_thumb.jpg
I think that tint might be a bit darker than factory post-135423-0-27558000-1441188253_thumb.jpg so a swap was in order post-135423-0-10390400-1441188372_thumb.jpg
Lots of room to work, no small access holes here post-135423-0-17185700-1441188507_thumb.jpg Bose vs Panasonic speaker (slightly different loom too) post-135423-0-36539900-1441188625_thumb.jpg
Machined discs and some EBC reds (PN: DP3775C for those playing at home)
and some touch up paint for a few chips post-135423-0-96303900-1441188787_thumb.jpg My 5 year old daughter cleaning the hub faces (PROUD DAD :sweat:) post-135423-0-62683400-1441188950_thumb.jpg
  • Like 1
Ordered a 32mm solid front swaybar & bush's (superpro) from GSL RalleySport for $229.00 posted.
?? I thought all Superpro are hollow items ??
Read that somewhere, due to keeping the weight down to close as stock item.
Just ordered the same myself, 33mm front and 22mm rear and new extra caster bush kit.
Also waiting on Dales brace :)
Edited by conan7772
Still by far the best upgrade I.m.o.
Response from mid to top end very tidy indeed. For me paired to the aftermarket 3" exhaust my fuel economy improvement has been the real big bonus tho...
Still very happy customer
Edited by TM35
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
