235/45/r17
the 45 doesn't mean 45mm wall height, it means that the sidewall is 45% of the width
18's with the right offset look good, and 19's would look good too
mine had 20's on it before i bought it and looked a bit silly really (rubber band thin tyres)
up front you will want roughly 18x9 +15 and on the rear i think you auto guys only need about +30
try to keep the same widths all round
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5634084
If he wants to go all out, he can go a fair bit further than that. My RS4 is running 18x9+18 all round, the rears sit pretty well like that, but I'm planning on spacing out the front 15 or 20mm to get them flush.
I believe RS-V has 50mm extra track at the rear compared to the RS4, so can go either wider wheels, or lower offset at the rear than the RS4 can.
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5634097
best is still 17", my mates r34 skyline has 18" and the look waaaay to big, but then again we got wagons, still prefer my 17" though :D
would opt for some nice 15" or 14" if i had more cash, 15x9 on front and 15x12 on rears :D looks sexy
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5634241
I really depends a lot on your suspension setup.
For example, I'm running an 18 x 9.5 +22 front and rear on my auto RS4V. With the car at stock height, the wheels stuck out of the gaurds by about 1.5". Mine is lowered to 340mm (from the centre of the wheel to bottom of guard lip) in the rear and it sits very nice and I haven't needed to roll the guards. I have fitted camber arms tohugh, as at that height, the inside of the rims where touching the coilover body.
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5634256
I'm running 19x9.5 +12 all round with spacers on rear (15mm or 20mm) 245-35-19 tyres without issue on my 260RS. The ride isn't great i'd probably go down to 18s if it was a daily.
I'll be going up to 255-35-19 next time i fit tyres though as i'm not really keen on the amount of stretch i have now.
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5635167
Cool thanks boys yeah it just a weekend car pretty much was looking at 18x8 and 18x9 d1rs with +19 wasnt to sure if that would if under proberly whats the chance of getting 18x10s under it or is that just dreaming?
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5635951
I'm not 100% sure of the differences in track width between the different versions of the C34. But seeing how 9.5 fits my car with stretch and a bit of camber, i would say 10s will fit but be pretty unpleasant to own and drive.
Edited by numleg
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5636046
I'm runnIng 18x8 +30mm V35 Skyline wheels with 245/40 tyres and I love the way my car looks. I'm not a fan of tyre stretching, though, and I managed to get these wheels at a great price.
Even better, my speedo is almost dead accurate!
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5637704
44915_107507565979622_100001611384497_60613_5772550_n.jpg62999_107507619312950_100001611384497_60614_5980253_n.jpg
180347_135971126466599_100001611384497_220843_600216_n.jpg165570_135971069799938_100001611384497_220842_4265379_n.jpg
for the time being before i get my 20s or even bigger if i can fit it... ive just got v35 wheels with 30mm spacers all round! makes the look of my car!...gotta see it from the back where you can see both wheels lol looks menacing.
dosent matter what wheels you have, spacers fix all... temporarily!!!
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5637920
I just put some 17 inch V35 rims on too, took the drifteks off as they will be my track rims. I noticed they have different offset between front and rear and had to run the +33 rears on the front, +30 front's on the rear. Yours the same Nick?
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5637955
The 17's clear the brembo/GTR callipers with space to spare, I couldn't pick it but it clearly states on the inside of the rim. (not that you would notice 3mm anyway) The problem was, the nissan centre caps wouldn't push in on one side as the centre is deeper on the front wheels due to the offset difference.
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5637984
fuark spewin... small spacers? lol...
its so hard deciding what rims to get for these f**kers... i DO want to go jap, but they dont go big enough. and its going to get me back over 5 grand lol
and look at the shit they are making these days lol
these are funky thou....
im not daring enough to try lol.....
http://www.talebtyres.com.au/products.asp?index=Forgiato
https://www.sau.com.au/forums/topic/351104-stagea-offset/#findComment-5638004
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
