Hey all,
Just an update on whats going on with my car, ive had a shitload of decision changes over the last few months but now its final and the car will be off the road for the next few weeks as of tuesday. Ive gone with the V8 engine. That being a Nissan Infinity Q45 car with a Vh45de, i pick the half cut up on monday. All the measurements were done at the wreckers and it will fit though some new headers will need to be made to clear the chasis rail but extractors where always going on neway so thats no problem.
The engine Standard Makes 280ps or 230kw's at the crank though many say this is under rated by nissan and it actually makes more. Ill be fabricating engine mounts at my dads factory as well as exaust manifolds, twin exaust system and then taking the car home to start on the wiring.
I will also be upgrading the breaks to 33 turbo items with custom made slotted and cross drilled rotors from DBA with my 4 stud pattern so i dont have to buy new rims, The car will remain auto with a stall convertor with the RPM to be discovered later as the car needs to be driven first to see where the best point for the auto to flare will occur. Only other costs other then steel will be a custom tail shaft and the diff is already a turbo item. The cluster will be changed to the infinity item and the nitrous will also be hooked up to this engine.
Ill try keep everyone updated and get a digital camera off a mate as mine decided to die and keep a picture diary as well. Aparently with extractors and some intake mods these engine make around 250kw's at the crank with bucket loads of torque and the best bit is no lag. Future plans for the engine will be a microtech system and blower for some serious fun. The best bit about the whole thing though is that the total cost of the transplant equates to less then the cost of a 25det half cut....
Cheers
John
https://www.sau.com.au/forums/topic/35764-time-for-na-power-the-wait-is-over/
  • Replies 390
Posted Images
Myself and my mechanic, have conducted heaps and heaps of research on a number of possible transplants and this one was the most unique so we went with it. The only possible drama's we can forsee is getting the auto computer to work with existing wiring in the car otherwise i will be changing everything which is not going to be fun.
Auto's are actually much better for drag racing, keeps times very consistant. Although yes i would prefer manual ill just see how it all goes first and recover from the current hole it has already burnt into my pocket.
not getting it too the ground will be the fun part!!
Picked up the half cut today and stuffed around as dad pulled out with letting me use his workshop though luckily my grandad said i could use his so i had to move it about and didnt really get a chance to do nething as i had to do stuff for uni tomorrow as well. Ill make a start tomorrow stripping the half cut and documenting where everything is meant to go and stuff.
Registration is simply a trip to the department of transport after its been engineered for them to sight the engine number. Insurance believe it or not is only 50 bucks extra a year through just cars.
I remember there is an equation based on the weight of the car to what size motor you can fit. Or something like that anyhow.
Hence in the R32 GTS-T you can fit a 2.6litre turbo. 2.6 is the largest legal turbo engine you are allowed to fit.
From memory in NA it was a 3.5ltr or 4.5ltr I can't remember?!?!?
Should be nice though.. Spin a few people out. :)
hey mate the rules in QLD are slightly different, its something like largest NA is something stupid like 6 ltr's and largest forced inducted is a little under 4.5, but what is engineered and mod plated is legal isnt it :) although it wont be force inducted for a while.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
