i honestly wouldnt though, it would ruin the look of the axis, imo anyway..
it could well ruin it but i think the extra air flow will be worth it................. any other options, maybe some round ones :P HAHA
yeah the grill is bigger but the lower section isnt all that big..........
the yellow section is open for air flow but the intercooler is in the red section so i thought i'd pop in the vents where the black section is for even more airflow...........
Get a bigger intercooler? :P
i went and bought a B&M trans-cooler (70264) this morning and fitted it already :D
ive done it the easiest way possible for now untill i do the intercooler cos i'll probly have to move it then.
just a quick one about tires and what i should be running.............
currently i have 245/40/18's which is the correct size acording to the AXIS broucher that says they come with 225/45/18's so that means i should run a 245/30/20........... according to my TOMTOM this is 10% out at 110 it says im doing 100.
so then in the owners manual it says to run a 225/55/18 which is the size compairable to what the normal M35's run so that means i need a 245/40/20 and then hopefully my speedo will be correct acording to the TOMTOM????????
cheers guys i just dont know which tyre i should be basing it off to get my speedo correct without finding out the hard way with a speeding ticket!!!
245/30/20 Nexen N3000's.............. dont really know how good they are but i'll soon find out i was told they should be better than the federal 595's i had on there but not as soft as a Yoki or a P-zero.
"Ultra High Performance Driving
  • Directional wide aqua groove design
  • Arrow center rib design-High speed driving performance
  • Shoulder design-Improved cornering stability
  • Aggressive type lateral grooves-Resists hydroplaning
  • W & Y - speed rated
  • UTQG 340AA"
Big thanks to Craig, Andy for putting in the shift kit and also Ian for the advice tonight :worship:
and the trans-cooler is working too :D
makes a difference thats for sure, full throttle shifts are great but the cruising shifts are a bit harsh IMO. :)
Lucky bugger!:nyaanyaa:
Mine goes in tomorrow night.:banana:
Edited by Daleo
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
