Hahaha Martin is now under more pressure than me for updates :P
Asked JEM for updates, waiting on them.... Will update the thread as soon as i know where it is up too....
Adam is working on the wiring today and is confident it will start on Monday, the fuel in the tank was stale so it requires cleaning before the 044 is dropped in for startup......
Possibly driving this home next week if everything goes smoothly, but it is a car..... And I've worked on it.... So I won't get too excited just yet....
In saying that the car is already booked for the July SAU Newy meet'n'greet, Nirimba Texi day and Marulan track day so I am hoping it's all good!
You know will be all good
Only issue will be the traffic driving home : )
All this power and about 20 highway patrol between start and finish of f3 : (
They won't know...... It's stock remember :D
:laugh: ^
Farkin, shouldn't have said anything about mine lol, you're all getting waaaaay ahead of me :P Now no one is going to enjoy my thread as much as I am because it will seem such an anti-climax :laugh:
Hope all goes well with your car man, but I'm sure it will all be fine. You're not retarded like me lol.
Edited by Hanaldo
Hahahaha you said you wanted motivation :D
Yeah car should be OK... And I am looking forward to a phone call saying its started and is running smoothly on the dyno ;)
Yeh I remember that phone call. It's the one that comes after it that you don't want :(
i was more referring to the urge to do top speed. :whistling:
dont forget you need to make pit stop at warnervale :yes:
I am a sensible SAU member :whistling:
Haha we will catch up for sure mate, can't wait to
See how yours performs, gunna be awesome!!! It'll be good to get results so we can hassle and motivate Hanaldo :D
Car is entered in -
Texi day July
Marulan track day
Car is gunna hopefully make -
Skyline nationals
SAU nationals
EC skidpan day
The local cruises are getting sorted thanks to the local boys, really looking forward to the SAU scene again :yes:
Your results don't count, you're cheating with the fruit juice! :laugh:
Your just jelly ;)
As we all are , that's why I said urge
Oh, and the update for today................
It runs! Cooling system bled, cams bed in :D
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
