I agree, this would make for an interesting result, perhaps even with the 3582 hta? I found your graph again the other day Owen, I still can't believe the response.
I would think a HTA3076 would be a bit wild if the TS works as well on it as it does on the 3036 Owen has, i would be inclined to go the 3582 in that case and make the power with epic response!
In saying that, any more power than i have now would probably take a bit of the fun away on the street and would push the internals past their limit which for me would not suit! I am certainly happy with what i have :yes:
Hey Mat, your breather setup looks stock but is your breahter setup the standard setup ;)? Wanting to convert mine to standard and get rid of the catch can setup but not sure if its wise with a motor with alot of stuff on it.
Yep, it's the standard setup mate.
If you look at the boost curve its got plenty more in it too, a flat line of 1.4bar would of made that graph even steeper..
My old turbo maxed out on 1.4bar so dont be surprised if Owens is basically out of puff... Not saying there isn't more in the setup, but he could have been getting near the limit of the turbo to some degree.... Where is Lithium to elaborate on this? lol
Wasn't yours set up in that same way by JEM? Sort of goes up to 28 then scales back for the rest of the powerband?
Both turbos did the same, yes.
The old 3076 was forced to 24psi and bled off to 20psi where it made peak power..... Keep in mind we made the similar power on 22psi bleeding to 20psi but got a little more out of it with the higher boost.
The new turbo graphs i still haven't seen as yet, I've been waiting for Adam to send the PDF's through too me so i can have a good look. I have only seen as much as you guys in terms of the big graph from the hero run. The turbo was run up too 28psi and bled off too around 24psi, the turbo/setup reached its limit... I think with a free flowing exhaust and holding the boost a bit would have seen the 400 mark possibly BUT that is putting a lot of heat in the turbo and engine AND i am running a stock engine and headgasket remember, i was shocked when i saw it survived 28psi and 391kw lolz.
Apparently some boost was taken out and it stayed at 387 so once i get all the graphs i can post them with the proper results...
thats with a 3inch dump still isnt it?
anymore mods comming matt? im thinking myself of buying an RB30 block to build over time. :P
Yep it is... Screamer did a lot of work too!
There will be maintenance mods etc but nothing big coming in the near future, it will be more upgrades of broken parts.
AND will be more using the car for what its built for rather than working on it ;)
When you taking me for a run matty? This saturday?? :woot:
Nope, Carmen will be driving the cruiser or golf i think... Will come say G'day and catch up for a feed for sure!
Wow that curve is pretty awesome - man a twin scroll HTA3076 would make for an incredible street RB25 setup, next step for Owen's car? :D
HTA3582 would be just nuts, probably similar response to a normal GT3076R but good for nearly 100rwkw more haha
i enquired with them, and they won't sell just the comp wheel and housing,
bastards!
Haha nicely put! :P BUT even nicer to know you are enquiring :D
If its all in the comp wheel and comp housing then could someone remake a comp wheel in a 0.7comp cover to replicate the same thing at a lower price? eg stao?
not sure if its being done already .. but doesn't HTA use garrett parts and just modify them?
just a thought
  • Like 1
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
