Had 225's on my 9.5s, perfect amount of stretch for a streeter going for stanced/aggressive look, but awful in the way of grip/handling/comfort. 265 will bulge slightly, assuming you are running 9.5's all round, 265s on the rear, 245s up front IMO. Feel free to disagree but on the rears you want grip for launch and power to wheels, fronts you need to be able to steer - where I believe 265's will be too large and only hinder turning capabilities.
Exactly the opposite of what i want :P
Look isnt a major concern, the car is built to function the best it can for a street nugget... It runs 235/40 and 265/35 now but i do have some understeer and i would rather balance the car with rubber instead of counteracting it with the swaybars (If that makes sense??)
Richo who is prepping his car for the WTAC and other time attack events runs the biggest tyres he can on all 4 corners.
He runs 285's on all four in his lil R33 Gts-t :)
Yep that i what i was thinking! Maybe its not ideal for street use which is fine, ill run 2 sets of rims.... Being a street car though it has to maintain pretty standard guards!
I want to get them rolled and pulled out to give me some extra room.... Just seems everyone that has run a 9.5 on the front has stretched a tyre and made it MOAR low :/
because racecar :P
:yes::woot::banana:
I'd be curious to see how you go with fitting 9.5's at the front with a 265 tyre.
At the track I had a 8.5inch +35 offset on a 245/40 tyre and it was still hitting the guard on tight bumpy corners.
Out of curiousity what tyres will you be running?
In any case I'm planning on going a 9.5inch + 22 offset rim + a 25/30mm hubcentric spacer at the front 265/35 tyre (AD08 or AD08R) ill just get some GTR guards to make it fit!
I see. I know I don't have the best of knowledge in these situations, but the theory I was going with was fairly right yeah?
Yeah fitting GTR guards would solve my issues but they look shit on a GTT and so much needs to be changed to suit.... Unless you do the rear guards too it looks silly....
I run an 8.5 now with a 235/40 tyre and do hit when hard braking + bumps and steering BUT i am raising the front of the car by about 10mm as its sitting too low according to Mr SK...
Tyre choice is yet to be made, i want to make sure it can be done before i get too excited and go but stuff!
Worst case ill run the nats on the size i have now but would prefer to have some grip to make up for the lack of driver skill :laugh:
What part of the guard was it hitting?
Only reason I say, is a 245/40 has a larger diameter then a 265/35.
I had the same issue on my evo, I ran 245/40R18 on it, and everytime I turned it rubbed the front guards. I changed to a 255/35 and it was perfect, even with stock guards. As soon as I went to a 265/35 it started rubbing on the back, so I needed to roll the guards, BUT it didnt rub on the fronts as the diameter wasnt as big....
Was that on your GTR rims?
Actually, from memory i think Kurtis is running 255/35 up front on his GTT... But i think that is on a 18x8.5 rim?
Hmmm interesting.... The Tridon says it flows more etc etc.... Not sure if the triple pass radiator changes the way the cooling system operates or not?
Yeh see that claim annoyed me. The thermostat isn't usually fully open, it shouldn't need to 'flow' more than the factory item. It's a simple thing that does a simple job, there doesn't need to be anything complex about it. If you are getting overheating issues, it's highly unlikely to be because your thermostat can't flow enough coolant. And comparing the two side by side, I couldn't see how they justified that claim anyway.
As for the radiator, are you sure yours is a triple pass not a triple core? My understanding was that triple pass radiators required the inlet/outlet to be on opposite sides, yours are on the same which tells me it must be a dual pass... Also, not that it matters too much, but just read this while looking for pics of your rad:
They look similar on the outside but this is a triple pass radiator, i found cheaper Koyo rads etc but after talking to a few people it seemed the N flo was a good design as it keeps the water in the radiator longer etc....
This doesn't make much sense to me... The coolant is in a closed system. So if it's in the radiator for longer then it is in the engine for longer, which can only increase temperatures.
If your understeering, have you tryed looking at alignment?
Some more positive castor, a little bit of toe out at front might do the trick... (provided you have sticky rubber!)
Yes, on my old R34 GT-R rims. I also used to run 255/40/17 SemiSlicks on some old R33 GT-R Rims. They used to rub a little on the rear as well.
Its what i was told by Racepace, its an Nflo which equates to a triple pass radiator i think?
And yeah i guess that makes sense in regards to the Thermostat too, what brand is the Nissan Genuine one? (I mean who manufactures them for Nissan?)
Alignment was good! Front was a tad too low but in terms of setup it was pretty spot on!
I have a lot of positive camber and also have toe out ;) Got that covered BUT i dont have sticky rubber........ And some asshole sold my wheels and tyres :P :P
Should have been MY 34 GT-R rims you nugget! They were black too! :no:
Ahhh quick google search showed me Koyo's NFlow design, clever system. So yeh, triple pass would work.
As for OEM thermostat; Hitachi... Maybe? Don't quote me on that, I can't actually remember. Probably just had Nissan stamped on it.
Maybe you should try something SLIGHTLY wider...?? 245/35/18?? In a nicer compound?
Haha, Well, I bring my rims back to maitland in two weeks, so we should try them on your car.. (they arnt sold yet!!)
Well with the R34 rims, you didnt want them at the time! Bet your kicking yourself now!!! I actually thought those rims suited the evo too... quite nice.
Edited by Tonba
Interesting about the height of the car and SK Comments
I've read that too and discussed it with Richo once as his car was quite low last year
I think his theory was something along the lines of it would probably work if your were into touring cars and riding every single high bump then maybe too low isn't good? Me no know, maybe Richo will read this post :P
But being low seems to work for Richo
Interesting
Yeah was rubbing on the outside of the tyre hitting the middle of the guard im pretty sure
Yeah that setup :) Post that shit in here so i can see :P
Hmmm, still leaning towards stock thermostat at this stage.
i have a smaller profile at the rears and i get the SLIP light at speeds above 100. 235/40/18 and 265/35/18
Nope you have another problem man as what you have is the same rolling diameter, i have run the same size as you for years and had no issues! Are you sure you werent just doing a skid? :P
Yep that is an option too! The RSR were just cheap shit for now!
We NEED to try them on the car so let me know when they are coming and organise a day to bring them round and have a BBQ etc? Or i can bring the car to yours and do the same? either way sort that shit out!
And yes, i am a dumb ass! :P
Interesting
EXACTLY what was happening too me. Rolling diameter was too large for my wheel alignment. I bet if you tried a 245/35 or a 255/35 that rubbing would go away.
Haha, sounds good mate. Im back for 4 days in 2 weeks time. We should catchup and do it. Bring your car over on the 17th, stay the night and we can play with it on sunday the 18th?
Being low in the 34 throws out the geometry of the suspension i think, the centre of gravity is out, bump steer issues, coilovers bottom out (they are only cheap stuff too).... There was quite a bit too it and i am probably giving all the wrong info BUT simple answer was to set the ride height about 8-10mm higher than it is now... Which will still look good and if it helps with handling then its win win!
I think it will reduce some scrubbing!
Lol be good to get some feedback from Richo actually ;)
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
