For the not so good news, the brilliant bonnet struts i fitted have been working well but i use the bonnet quite a lot unlike the others i guess and it has created a weak point in the bonnet and it has now effectively collapsed... Its dissapointing as the bonnet was repainted and looked pretty good up until now -
I guess this was just a freak failure and i dont think there is anything wrong with the actual product.... They are a good price and worked well, maybe too much use :(
I wouldn't bother with the temps at the hillclimb. You're not going to get them warm enough to gather decent data, and by the time you make it back to the staging area, they are going to be cooled of any heat you did make. Did he show you how to take temps?
Nope there will be no temps taken at this event! No point and i dont have the gear as yet....
Yes he showed Carmen how to do it as she is in charge ;) Gotta get a proper pyrometer etc
Anyway, representing SAU at the Nulon Nationals means time for some Nulon oils -
Corporate-Logo-black-background_zpscc39a
Gearbox was a bit grubby as usual... Am going to have to mod the breathers before the next track day as both the gearbox and diff are pushing their love juices out all over the place :no:
Mat, that's generally an indicator that the gas struts are carrying too much pressure for their allocated task.
Bonnet struts don't need a great deal of pressure in them; otherwise they basically become a load point like yours have done.
This kind of damage is super common on Alloy, Fibreglass & Carbon Bonnets.
The Strut re-gas guys can set strut pressure to suit particular appilcation; this will prevent a repeat performance.
I've had hatch struts gassed at a higher pressure to allow for a rear wing before.
I think this guy will be the closest to you? They are mobile; so they come to you.
Strut Re-gas Hunter
Arie Oosterveen
Cnr Church & Foundry St
Wickam NSW 2293
Ph: 02 4961 3255
  • Like 1
Yeah that was my guess, good info mate!
Not sure if i can salvage the bonnet and just keep it for now until the car becomes more track based down the track! I want to keep the nice stock look if i can!
thanks for that. am going carbon bonnet soon and was going to use my current struts. you might have just saved me an expensive bonnet! thank you.
Bugger about the bonnet Mat, I sure hope the struts don't kill mine.
Will be interesting to see what you think of the Nulons too.
I have been using them for the whole time I've had the 33 and the 31 now is primarily Nulon filled too.
No complaints here, improvements more than anything. :D
This is your friendly reminder.
Pletty Prease.
Lol sonofabitch! I just saw this friendly reminder... The next event is at Wakefield and i assume you WILL be coming to watch ;) Then you can grab some while you are there...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
