For the not so good news, the brilliant bonnet struts i fitted have been working well but i use the bonnet quite a lot unlike the others i guess and it has created a weak point in the bonnet and it has now effectively collapsed... Its dissapointing as the bonnet was repainted and looked pretty good up until now -
I guess this was just a freak failure and i dont think there is anything wrong with the actual product.... They are a good price and worked well, maybe too much use :(
I wouldn't bother with the temps at the hillclimb. You're not going to get them warm enough to gather decent data, and by the time you make it back to the staging area, they are going to be cooled of any heat you did make. Did he show you how to take temps?
Nope there will be no temps taken at this event! No point and i dont have the gear as yet....
Yes he showed Carmen how to do it as she is in charge ;) Gotta get a proper pyrometer etc
Anyway, representing SAU at the Nulon Nationals means time for some Nulon oils -
Corporate-Logo-black-background_zpscc39a
Gearbox was a bit grubby as usual... Am going to have to mod the breathers before the next track day as both the gearbox and diff are pushing their love juices out all over the place :no:
Mat, that's generally an indicator that the gas struts are carrying too much pressure for their allocated task.
Bonnet struts don't need a great deal of pressure in them; otherwise they basically become a load point like yours have done.
This kind of damage is super common on Alloy, Fibreglass & Carbon Bonnets.
The Strut re-gas guys can set strut pressure to suit particular appilcation; this will prevent a repeat performance.
I've had hatch struts gassed at a higher pressure to allow for a rear wing before.
I think this guy will be the closest to you? They are mobile; so they come to you.
Strut Re-gas Hunter
Arie Oosterveen
Cnr Church & Foundry St
Wickam NSW 2293
Ph: 02 4961 3255
  • Like 1
Yeah that was my guess, good info mate!
Not sure if i can salvage the bonnet and just keep it for now until the car becomes more track based down the track! I want to keep the nice stock look if i can!
thanks for that. am going carbon bonnet soon and was going to use my current struts. you might have just saved me an expensive bonnet! thank you.
Bugger about the bonnet Mat, I sure hope the struts don't kill mine.
Will be interesting to see what you think of the Nulons too.
I have been using them for the whole time I've had the 33 and the 31 now is primarily Nulon filled too.
No complaints here, improvements more than anything. :D
This is your friendly reminder.
Pletty Prease.
Lol sonofabitch! I just saw this friendly reminder... The next event is at Wakefield and i assume you WILL be coming to watch ;) Then you can grab some while you are there...
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
